From tamiyablog :
XV-01 PRO Chassis kit
Motor suspension features only enhance the covered some in the dirt to the chassis structure was sealed radio box that are friendly to dust resistance The rally chassis multi-purpose can accommodate the road and various other parking and off-road, the belt drive PRO Chassis Kit to realize is standard equipment Motor production item is sold separately spot OP TRF damper parts, such as strengthening and universal shaft driving belt stable by placing the front overhang.
Tamiya kit assembly XV-01 PRO Chassis Kit Electric RC 1/10 [tentative name] is a limited item.
Off-road and parking, a multi-purpose chassis rally appeared.
Adopted the suspension only increase the dust covered some excellent chassis structure, in the dirt.
Driven layout is put on the front overhang and weight of the motor is belt drive, run a certain sense of stability even realize.
The PRO chassis kit was equipped with a standard OP enhance TRF damper parts, such as a belt drive shaft universal and improved, the quality of the ride.
Finished in compact gear box while keeping the front motor split into upper and lower motor is adopted considering the maintainability of the gear.
OP was prepared as off-road parts to the road surface changes from moment to moment is essential, a slipper clutch also.
Radio box (chassis)
Dust-proof radio box that are friendly to the most anxious in the off-road riding.
Also equipped with four-wheel inner fender, each hatch is screwed.
The space is also equipped with ESC-like duct removable cover, we have also taken into account design and exhaust heat.
The battery is the battery access hatch chassis from the bottom.
As an internal structure with a packing cover, radio box and leads, in the hatch has also been completed at the connector connection.
Adopt a long steering tie rod steering proven in touring car.
Structure difficult to lock the discharge port is provided, such as pebbles at the bottom of the chassis.
Only type suitable for off-road riding with improved suspension arms also covered some also.
Rear suspension rear suspension geometry was adopted reversible.
Stroke in addition to securing a higher ride height in mind off-road riding, you can quickly adjust the toe angle as well as another body in the suspension mounts.
Part XV-01 PRO Chassis Kit as standard:
TRF damper
Universal 4-wheel shaft
Full Ball Bearings
Enhanced belt drive
Aluminum Turnbuckle (Blue)
Could this be the secret limited edition kit discussed here? http://www.tamiyaclub.com/forum/index.php?showtopic=65747
Intriguing. I hope it's a new rally car chassis. I love rally and would like a real rally chassis for competition.
I'm pretty sure it is. I just hope it's a completely new chassis - sounds like it is from what I'm reading right now, but of course based on the reversible suspension arm system. It sounds really promising, let's hope Tamiya can surprise us positively! :lol:
And eh, just as a side note: Have you noticed the FF03? It says 'newly designed gear case with a built-in Giyadefu'
Gear diff, anyone? Please? ;) Perhaps then there will finally be a gear diff for the TRF201 too (The Kyosho Ultima DB/SC one fits with some modifications, but it's expensive buying all the seperate pieces).
Yeah, that would be a gear diff for the FF-03
Can someone post the original Japanese site please?
Reading the translated English gives me a headache. But, it looks like it may be front motor 4WD belt driven... weird.
This website has a price already. 32340 yen ($400US) RRP
List price 19404yen ($240US)
Update: reading the Japanese on the the site above TELLS me the motor is a front overhang type!!!
Oh and apparently the kit number is 58526... even though it's supposed to be limited?
Without wanting to read too much into an upcoming release, I think this COULD be very promising news when you bear in mind that there were rumours the re-re trends would end with a really big one. We've just had the Bruiser, and now we're getting news of what looks like an entirely new chassis. Could the big T finally be back on their game and this be the beginning of a load of genuinely new stuff rather than re hashed rubbish? (Yes I know that's a bit harsh, but I'm sure you can sympathise)
Sounds like this might be a better chassis for drifting than rallying with the front motor overhang; the weight is distributed towards the front and with a belt it should be relatively easy to do some countersteer modifications...
-Paul
From tamiyablog :
58528 Impreza 08 Arai (XV-01)
84291 XV-01 Titanium Screw Set
54376 XV-01 Separate Suspension Mount (XJ)
54377 XV-01 Separate Suspension Mount (XM)
54378 XV-01 Slipper Clutch Set
54379 XV-01 Aluminum Suspension Mount (XJ)
Really looking forward to seeing what this new chassis looks like. Sounds like a high end bit of kit.
