Nice, Vaughn [;)]!
I put Kyosho oil dampers on my WW2, and I did some remodeling and extended the piston arms on the back ones so they're a bit longer than original Kyosho short ones. Improves the handeling of your WW a lot! [:D]
quote:Originally posted by simensays
Nice, Peter!
id="quote">id="quote"> awesome Simen here soon you will have a new in box original wild willy[;)]...........i bought them shocks for my wild willy 2..if i got to sell all my nice buggys im going to enjoy atleast a little of the money the rest for bills[:(]
update yes they do fit the shock set comes with different sets of bottom threaded shock mounts just use the longer ones if you plan to use on the wild willy 2......you will loose a little travel in your suspention,but actually its good as it makes the rear drive shafts level to the gear box which in turn means more power[:P]
yes your right they are made for onroad racing but they work for off road just *** good.........actually the tamiya recomended hop up shock for the wild willy 2 is ta-03 shocks which also are really made for on road cars[;)]
  • 1 year later...
My TA03's for Wild bill have arrived this week, but of course they didnt come with any damper oil, anyone got suggestions on what damper oil should go in a monster truck suspension?
I presume soft?
quote:
I presume soft?
Those mini CVAs are pretty short-throw, soft to medium is the go.
Maybe try 40wt with 3-hole pistons (or 30wt with the 2-hole).
