Hi Guys,
What are the correct wheels and motor for an Avante with all Hop-ups?
Did Tamiya ever release an Avante Optional Parts sheet?
Chris
The #84280 lightweight wheels with hybrid spike tires from the Egress/Vanquish would be considered a period correct hop-up. The correct motor would be the 540 VZ Technigold, or a Dynatech 01R or 02H.
Other hop-ups from memory...
* #53010 Ti screw set
* #53031 front posi-joints
* #53032 rear posi-joints
* #53033 ball race steering
* #53034 torque splitter and dual ball diffs
* #53035 ball end cover set
* #53038 carbon chassis
- James
Pretty much the first 55 hop-ups Tamiya came out with in their 53xxx line were aimed directly at the Avante and competition racing. Of course if you put all those hop-ups together you're just left with an Egress.
- 53001 - Dynatech 01R Motor
- 53002 - Dynatech 01R Rotor
- 53003 - Dynatech 01R Brush
- 53004 - Avante rear springs (Soft)
- 53005 - Avante Lightweight Wheels (front)
- 53006 - Avante Lightweight Wheels (rear)
- 53007 - 1680 Sealed Bearings 4pc
- 53008 - 1150 Sealed Bearings 4pc
- 53009 - Avante Titanium Rod Set
- 53010 - Avante Titanium Screw Set
- 53011 - 3x6mm Titanium Machine Screw x10
- 53012 - 3x10mm Titanium Machine Screw x10
- 53013 - 3x15mm Titanium Machine Screw x10
- 53014 - 3x20mm Titanium Machine Screw x10
- 53015 - 3x8mm Titanium Tapping Screw x10
- 53016 - 3x12mm Titanium Tapping Screw x10
- 53017 - 3x15mm Titanium Tapping Screw x10
- 53018 - 3x10mm Titanium Tapping Screw x10
- 53019 - 3x18mm Titanium Countersunk Screw x10
- 53020 - 3x8mm Titanium Countersunk Screw x10
- 53021 - 3mm Aluminum Nut x20
- 53022 - 3mm Aluminum Locking Nut x10
- 53023 - 4mm Aluminum Nut x20
- 53024 - 4mm Aluminum Flange Locking Nut x10
- 53025 - Silicone Damper Oil Set (soft)
- 53026 - Silicone Damper Oil Set (medium)
- 53027 - Silicone Damper Oil Set (hard)
- 53029 - 1150 Sealed Bearing 2pc
- 53030 - 850 Sealed Bearing 4pc
- 53031 - Avante Posi Joint Universals (front)
- 53032 - Avante Posi Joint Universals (rear)
- 53033 - Avante Ball Race Steering Set
- 53034 - Avante Ball Diff & Torque Splitter Set
- 53035 - Avante Ball End Cover Set
- 53036 - Hi Cap Damper Set (mini)
- 53037 - Hi Cap Damper Set (short)
- 53038 - Avante Carbon Chassis Set
- 53039 - Hybrid Narrow Spike Tires
- 53040 - Hybrid Wide Spike Tires
- 53041 - Dynatech 0017 Rotor for 01R (hop up 17T rotor)
- 53042 - RC Ball Diff Grease Set
- 53043 - Ball Diff Internal Parts
- 53044 - Dynatech 02H motor
- 53045 - Undercowl for Avante Carbon Chassis
- 53049 - Lightweight Narrow Wheels (black)
- 53050 - Lightweight Wide Wheels (black)
- 53051 - Dynatech 02H brush set
- 53052 - Dynatech 02H 6513W Rotor for 02H (standard 13T rotor)
- 53053 - Hi Cap Mini Spring Set
- 53054 - Hi Cap Short Spring Set
- 53055 - Racing Rear Wing Set
- 53062 - Dynatech 02H 7010W Rotor for 02H (hop up 10T rotor)
- 53052 - Dynatech 6513W Rotor for 02H (hop up 13T rotor)
I am sooooooooooo happy to have them all on my vintage collection :)
