MSM546 10 Posted May 14, 2012 Basically I have a R470 cab which is already sprayed but im not too happy with the finish. I was windering if i could simply prime over the existing paint and spray a new topcoat or would i have to strip all of the paint off first??? Thanks Share this post Link to post Share on other sites
bromvw 744 Posted May 14, 2012 Basically I have a R470 cab which is already sprayed but im not too happy with the finish.I was windering if i could simply prime over the existing paint and spray a new topcoat or would i have to strip all of the paint off first??? Thanks just how bad is the paint ? if its just orange peel it may be possiable to use rubbing compound and rub it back to a decent shine . Once done a coat of clear will add the gloss finish back .If you can post a good close up it will be easier to advise you . Share this post Link to post Share on other sites
MSM546 10 Posted May 14, 2012 its just that the paint is thin in some areas (i think i used too much cutting compound) so i was thinking can i just spray on top of the existing paintwork or would i prime it first and spray the top coat on top??? Share this post Link to post Share on other sites
bromvw 744 Posted May 14, 2012 its just that the paint is thin in some areas (i think i used too much cutting compound) so i was thinking can i just spray on top of the existing paintwork or would i prime it first and spray the top coat on top??? give it a really good clean with washing up liquid and warm water . You should be ok giving it a few light coats over the existing paint . Share this post Link to post Share on other sites
MSM546 10 Posted May 14, 2012 give it a really good clean with washing up liquid and warm water . You should be ok giving it a few light coats over the existing paint . Cheers mate , will try it and see what happens... Share this post Link to post Share on other sites
bromvw 744 Posted May 14, 2012 Cheers mate , will try it and see what happens... leave it a week or so before re buffing mate to let the paint fully cure . Share this post Link to post Share on other sites
Panther F 0 Posted May 26, 2012 I would just knock the shine off with some wet 600 or 800 grit WITH water, then re-coat with the paint of your choice. ~ Jeff Share this post Link to post Share on other sites
