tickz 0 Posted May 20, 2012 Hi all, Its been a while but im trying to sort the Monster Racer I found on a skip! http://www.tamiyaclu...showtopic=56809 When I found it I needed to buy drive shafts to get it going. its a good car and my son loves it but it slips like mad. It had a silver can in it and slipped from day 1, I stripped the diff down and cleaned it etc and put ball grease on, put it back together then put a dirt tuned motor in. it still slips like mad, I know that they slip but this seems excessive (even with the silver can in). before I strip it down again can I ask if anyone has any experience with this issue and how they sorted it. I have goggled and had a look around but Im not getting alot back. Im wondering if I havnt tightened something up enough? or I have notice in the instructions it states....14 *differential can be adjusted by using more or less spacers.....(see below) any help would be appreciated, its a good car! thanks dave Share this post Link to post Share on other sites
chris18 0 Posted May 20, 2012 Dave does it move at all ? Share this post Link to post Share on other sites
tickz 0 Posted May 20, 2012 yep moves but slips like mad until full speed, im just putting it back together, i found that it didnt have the SE7 shims in it at all, ive put some small shims I had lying around in and tightened it right up, gonna see how it moves now............. Share this post Link to post Share on other sites
tickz 0 Posted May 20, 2012 update!....sorted! moves a treet now,still a little slip at full but apparently expected. ive got a dirt tuned in and put a 4300mh batt, and it was flying! I might put an ez run brushless in?? whoever had it before didnt put the SE7 shims in, they could never of had it running correctly, thats why the knobbles on the tires was still good- now they are half gone! Share this post Link to post Share on other sites
chris18 0 Posted May 20, 2012 update!....sorted! moves a treet now,still a little slip at full but apparently expected. ive got a dirt tuned in and put a 4300mh batt, and it was flying! I might put an ez run brushless in?? whoever had it before didnt put the SE7 shims in, they could never of had it running correctly, thats why the knobbles on the tires was still good- now they are half gone! sorted !! Share this post Link to post Share on other sites
berman 5315 Posted May 20, 2012 Those tyres are worth a mint now as they are so hard to find, you will be able to see 10 pound notes fly off everytime you mash the throttle Yes the SE7 spacers are what you need to keep this diff running, everytime you sand the ball plates you will have to space them with these and the original spacers aren't easy to find, plus if you over space/tighten it the balls get flat spots and the diff feels notchy/gritty. But to be honest, it's a waste of time. The diff is really only designed for the buggies it came in, and even then it's debateable. That little ball diff struggles to shift the weight of the monsters and Tamiya should have relaced the ball diff with a planetary gear diff when they decided to put this gearbox in these trucks. Once you've fixed it, leave a slivercan in it. Try to tell your son not to do the backwards-slam-it-into-forwards thing and it may last you a good while. READ: Do not put hot motors in this gearbox or you will be back to square one. Do so at your own peril. If you are feeling rich, save up and look out for a 'Tamiya Super Astute TTC Gear Train', or an 'A&L Lethal Weapon' belt driven gearbox. Thorp also made some gearbox parts including a new ball diff, but I haven't heard if any other member have had success with this. Hope that Helps. Share this post Link to post Share on other sites
HunterZero 76 Posted May 21, 2012 Yes as you've found, those little diff springs/shims are pretty important... The diff balls might have been flatspotted after incorrect diff assembly, would probably remove all the slippage if you replaced those as well as the correct disc springs/washers (the tolerances in those diffs are pretty tight). I'd suggest ceramic balls if you must use crazy power, or you could melt the diff spur gear. - James Share this post Link to post Share on other sites
wildwillydriver 33 Posted May 21, 2012 <p>I know very well the issue and it was covered more than one time, here below an old post about this with some info.Hope this help. http://www.tamiyaclu...king +cab +diff If you are feeling rich, save up and look out for a 'Tamiya Super Astute TTC Gear Train', or an 'A&L Lethal Weapon' belt driven gearbox. Thorp also made some gearbox parts including a new ball diff, but I haven't heard if any other member have had success with this. Hope that Helps. http://vintageteamaandl.com/ Share this post Link to post Share on other sites
