Sign in to follow this
FLEXUS
FAILSAFE
Hi guys
I,ve got the failsafe set so the throttle is at neutral and the car turns hard left.
my first question is if i run the car then turn the TX off to test it the failsafe kicks in after about 3 seconds.
is this correct as i thought it would kick in immediately as soon as the TX is switched off?
my second question is how do you set the failsafe so the car brakes?
if while setting the failsafe i pull the throttle back to activate the brake this causes the car to run in reverse if the failsafe kicks in.(hence why i set the throttle position to neutral).
cheers Karl
Hi Flexus,
the failsafe needs indeed a little time to notice the loss of radio signal. How much time is depending on your radio gear.
For electric powered cars, just have the trottle in neutral position when setting up the fail safe "brake".
Hi Flexus,
Alright Greg
thanks for confirming that i,ve got the failsafe set correctly.
cheers Karl
