It says in the directions that when cleaning or changing brushes, or cleaning commutator, to replace the plastic bearing with a regular steel ball bearing. Now my question is does anyone know the size of the bearing I need to replace it ? The directions fail to mention that detail.
You can measure the existing plastic bush. Bearings are sold by size.
A x B x C, where A is the shaft size, B is the overall diameter, and C is the width of the bearing.
So a 5x11x4 (common bearing used in a Tamiya - 1150) fits on a 5mm shaft, inside an 11mm housing, and it's 4mm wide.
Yup, what Mark said. Here's an another way of "measuring" that same 1150 bearing he used as an example. Outer diameter = 11 mm, Inner diameter = 5 mm, and thickness = 4 mm. Exactly the same bearing used in both examples, the ever-so-common Tamiya "1150" bearing.
Just measure the plastic bushing using eihter of these methods, and you have your size.
