Hi everyone, just a quick question. Can you lengthen the wire from the esc that goes to the motor? The esc i have has leads that are 75mm & they dont reach the motor :( they only need to be 30- 40mm longer is this ok? I'm only asking because someone said the length was gauged for volt drop - bla-bla & it wasn't possible.
Thanks :wacko:
You can lengthen the wires, just use the same gauge. The longer the wire the more resistance it will have so keep things as short as possible. For a sensorless brushless setup keep the lengths the same since the ESC will rely on the feedback through the wire to detect the rotor position.
