94grasshopper 0 Posted September 15, 2012 will this fit in to my grasshopper 1 and if so will i need anything else for it to fit thanks kyle http://www.amazon.co.uk/Ezrun-Hobbywing-Combo-3000Kv-Brushless/dp/B0092MQHUY/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=1B9OANH2SP8WM&coliid=IBJIYJY8WBZ8W Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted September 15, 2012 Yes that should fit in place of a standard silver can 540 motor, the only thing I would reccomend is a cheap lipo battery to run it, it will run fine with Ni-mh or Ni-cad but lipos will blow you away. I would advise shopping around though, it can be had for a lot cheaper, in fact for that price you could get a lipo as well from places like hobbyking. Share this post Link to post Share on other sites
94grasshopper 0 Posted September 16, 2012 Yes that should fit in place of a standard silver can 540 motor, the only thing I would reccomend is a cheap lipo battery to run it, it will run fine with Ni-mh or Ni-cad but lipos will blow you away. I would advise shopping around though, it can be had for a lot cheaper, in fact for that price you could get a lipo as well from places like hobbyking. i would do but ive got a voucher for amazon so want to spend it on there is there any others on there that people have used and work well? Share this post Link to post Share on other sites
atf300 28 Posted September 16, 2012 i would do but ive got a voucher for amazon so want to spend it on there is there any others on there that people have used and work well? thats a solid system , and actually , you wont be able to get the same from hobbyking , comparable yes but not the same , also this is in the uk so no customs. go for it ! just make sure you have a steel pinion installed. Share this post Link to post Share on other sites
94grasshopper 0 Posted September 16, 2012 thats a solid system , and actually , you wont be able to get the same from hobbyking , comparable yes but not the same , also this is in the uk so no customs. go for it ! just make sure you have a steel pinion installed. yeah ive got a new pinion when i put my 540 motor on it :D Share this post Link to post Share on other sites
94grasshopper 0 Posted September 16, 2012 one more question before i get what sort of plug will it have will it be the same as the lipo battery or the same as normal battery Share this post Link to post Share on other sites
atf300 28 Posted September 16, 2012 i think you will have to solder the connector your choice Share this post Link to post Share on other sites
TA-Mark 195 Posted September 16, 2012 one more question before i get what sort of plug will it have will it be the same as the lipo battery or the same as normal battery Avoid the Tamiya style molex plugs. They cannot handle the amount of current needed for a brushless system. Stick with high voltage battery connectors. Share this post Link to post Share on other sites
mr nice 10 Posted September 16, 2012 It should come with a tamiya plug as mine did and by the way ebay hong kong do this for about £50 deliverd an takes about a week. Share this post Link to post Share on other sites
