wolfdogstinkus 1876 Posted October 2, 2012 I just bought a micro servo for fun, maybe to turn a drivers head?, or to open the sunroof on the beetle, problem is that the maximum voltage the servo can take is 4.8volts, it got a bit hot after a couple of seconds plugged into the receiver when it must have been getting 6v, oops. The servo still works but I need a way to step down the voltage?, can I just use a couple of AA batteries?, and if so do I take the + and - wires to the batteries and leave the other wire in the receiver?, would this even work?. Share this post Link to post Share on other sites
bromvw 743 Posted October 3, 2012 Hello mate . You can run the micro servo off the reciever by fitting a potentiometer or resistor to drop the voltage . You'll need a volt meter to set the voltage . Its the same as fitting resistors to LED's when using them for headlights ect . A resistor /pot with a value of around 560 Ohms should do the trick Share this post Link to post Share on other sites
wolfdogstinkus 1876 Posted October 3, 2012 Thanks Bromvw, I don't have a voltmeter but I could probably borrow one from somewhere, I have always got my led's with resistors all ready fitted so don't have any experience with them. I can solder ok so no problem fitting one, just need to know what to buy. Share this post Link to post Share on other sites
Backlash 481 Posted October 4, 2012 Your best bet would be to use a 7805 Voltage regulator to lower the voltage.. A 7805 regulator will output 5 volts.. Another option would be to connect 2 diodes (IN4004) in series in the positive (red) servo wire.. A diode has a fioward voltage drop of appro 0.5 volts, 2 diodes will drop the voltage by 1 volt.. The easiest option would be to use an ESC with a 5 volt output on its BEC.. Share this post Link to post Share on other sites
trf_414_m2 5 Posted November 13, 2012 My experience about different voltage rated servos is what I saw few months ago in a friendĀ“s electric helicopter only. Due to the high voltage/power motor demands, he had to use a no BEC esc. Then he powered all main rotor servos and receiver by a 6v lipo regulator, and get a 4.8V lipo regulator for tail servo only. Weird setup, but completely a must as he told me. Share this post Link to post Share on other sites
bromvw 743 Posted November 13, 2012 Your best bet would be to use a 7805 Voltage regulator to lower the voltage.. A 7805 regulator will output 5 volts.. Another option would be to connect 2 diodes (IN4004) in series in the positive (red) servo wire.. A diode has a fioward voltage drop of appro 0.5 volts, 2 diodes will drop the voltage by 1 volt.. The easiest option would be to use an ESC with a 5 volt output on its BEC.. same as fitting a resistor or pot in efftect - drop the voltage . Share this post Link to post Share on other sites
