Painted and fitted, Willy is now armed and dangerous!
DSCF1690
DSCF1691
It's almost invisible from any distance but it was still worth the effort
DSCF1693
cheers,
Rob
Thanks Mirrorman, you're very kind. I've got a few ideas to finish this off but I've been working on something else recently. Will be back to this soon...
  • 2 months later...
Well I said I'd be back to this, so here is the last little dash of insanity.
Passenger?
P2280015
Handcuffs / shackles!
P2280016
The figure is modded a bit to sit more upright
P2280017
In he goes...
P2280022
P2280024
P2280025
You can see the servo wire in the first pics. This one's connected to the ESC channel so when the truck goes forward, Willy looks back at his disappearing freedom!
This is just about done now. I need to play with spring rates to try to get it a bit more stable, all the body mods have added quite a bit of weight so it's very top-heavy. There's always something, isn't there...?
Cheers,
Rob
That is so great! I thought you'd put him in the passenger seat, but I didn't expect to see him in the back! HAhaha....
Perfect! You're a WW Genius! Would love to see a vid!
Cheers,
Skottoman
  • 1 year later...
Another great build I'm just discovering. Your work is truly inspirational Rob!
What kind of servo are you using for the Willy figure, any photos of the rear of the driver showing the servo install?
Nito
Thanks Nito!
The servos were cheap Hextronic jobs, a couple of quid on ebay. I thought I had a photo of the install somewhere but if I did I can't find it, sorry. From memory, the mounting tabs had to be cut off the servo and the hole in Willy's neck enlarged. The servo is just hot-glued in place.
cheers,
Rob
