I seem to recall that the F104 has a longer wheelbase than the F103, by about 10 mm (270 mm for the F104 v. approximately 260 mm for the F103). Mounting points for bodies would also change due to the F104's centrally-mounted battery compared to the F103's placement, but from photos it does not appear to be by much.
You could try to make it fit, but I feel the end result will not be what you were looking for unless you do not plan to make a McLaren for your chassis. There is at least one aftermarket company that makes both modern and vintage F1 bodies for the F103, though.
