The ball joints on the steering uprights clip into plastic cups on the front arms. As the cups wear, the ball joints can pop out. Tie wraps help keep the whole assembly together.
I think the Super Champ kit included the tie wraps and an additional step in the instructions to install them.
+1
spot on description and never a bad thing to use cable ties on new parts too
I have a better idea so it don't look ugly what if i knot like 12 piund fishing line around them would this be good you won't see it also?
does it have to be tight or loose around the A arms?
THANKS
Shen
THANKS
Shen
just do the zip ties up so they are fairly tight but not overly so , if you use clear ones you hardy see them .
