Just ordered myself a Hotshot for christmas and wondered what kind of power it can handle without wearing it out too quick, ive got a 8.5t ezrun brushless combo sat doing nothing and thought about putting that in.
Tamiya101.com recommends a brushed GT Tuned motor (25 turns) to get started with the Hotshot. I don't know if it runs fine with a 8.5 turn brushless, but I'm sure someone else will be able to give you advice.
Don't know if it's as indestrubtible as a Blitzer Beetle gearbox, but i've been running a 9T BL in a BB for a while. Gearbox has nowear whatsoever..
Probably the Hot Shot can manage a 8.5 turns but wearing will improve a lot.
You absolutely absolutely need a steel pinion gear.
Max
I was running a 5.5 for some time & it did kill the gears ( but i didn't have the steel pinion ) & did have thrust bearings .
So with all bearings in , I now run 10.5 , as the 5.5 was just nut's = (just pulled wheel stands all the time ).
So with the 10.5 in & turned down to suite the track , as that enough . With steel pinion in , I have had no problems .
The biggest problem was the dog bones & out put shaft's wearing fast & that is getting costly .
In addition to the gear-train durability, there is also the little problem of the near-zero airflow in the Hotshot chassis, but with the right steel pinion gear it should handle brushless power while keeping temperatures down. I would agree that 8.5T seems to be a little too much, however.
Well ive ordered the bearing and an 13t and 15t rw racing 32dp steal pinions, i use these in all my cars, might just fit a 20t motor with the 13t pinion to start me off and fit the brushless setup in something else, maybe the grasshopper lol.
I did think about getting a 13turn ezrun motor to go with the 60amp esc but was concerned about lack of airflow for the esc after looking at the online manual, so might stick with a brushed setup for now. Cheers guys for your input.
That is the only issue, and one that really says stick to brushed (especially if you were only thinking about a 13T brushless any). The electronics box is pretty tight too so be wary of the size of receiver and esc you select.
all my ezrun ESC's have a fan on top so it should not be a problem with it if you get the ones with the fan...also with that 13 turn motor a 35 amp will be fine if you get the 380 sized 540 tacom or ez run motors.
I've fitted an Ezrun 8.5T in my re-re hotshot. It runs ok on an 8.4V NimH with no gearbox crackle, no idea what it will be like on LiPo though. I mounted the ESC directly under the radio access tray, then machined 2mm wide cooling slots in the radio access plate. I also had to remove a small amount of plastic from the mech deck in order to get all 3 motor wires out of the mechanism box. I can try and find some pictures to post up this evening if you're interested.
I have been running a EZ Run 13t with a 60amp ESC with no problems. 15T steel pinion, Ball raced and Top Force Unis all round. Li Po's of course.
Don't mash the throttle on the landings of jumps & it will be fine. Any more than a 13t motor and the chassis will be over powered.
Well ive got a 20t hpi motor, modelsport rv12 assault lipo friendly esc, 13 and 15t steel rw pinions and bull ballraces, will be running on 2s lipo's and will see how it goes.
give the 8.5 EZRUN a try . if will be like excrement off a navvies shovel but the gearbox will cope with it IMO . you can always drop the 20t in if you find its too fast .
HI!... In my BIGWIG (custom aluminum chassis) I'm running a EZ-RUN 5.5T 6000KV BL system with a steel 19T pinnion and a 60 AMP EZ-RUN ESC. Full sealed ball bearings. The BigWig and HotShot use the same front/rear gearboxes. I've run mine on a 11.1 lipo with no issues. Does 51MPH on 11.1 and 43MPH on 7.4 LIPO. The only issue I had was the stock driveshaft started to get the "skipping rope" effect and was cutting into the top of my lipo batteries. So I fabricated up a custom driveshaft from a E-REVO.
Here's some pics of the EZ-RUN installation in my re-re hotshot.
It's a tight fit with the speedo but it can be done. I also replaced the ezrun on/off switch with a more conventional one that could bolt directly to the hotshot on/off switch mount/hole.
That seems a bit slow for a 6000KV motor. I've been getting very close to 50mph with my thundershot using a 4000KV eZrun and a 10.8Nicad, which is quite a bit heavier than a LiPo. Perhaps your gearing is a little high for the motor ?
HI!... Because of the custom aluminum chassis, the car weights twice of what a stock BigWig does. Plus I have smaller than stock diameter road tires on it. Also I've got it tuned way down. If I want speed in a off-raod buggy, I'll just use my Caster Fusion 1.5R. It does 120KPH. LOL!
Thanks for the extra info on that. My previous comment was not a dig, I was genuinely intersted as I'm considering buying a 6000Kv Ezrun for my DF-02 that currently has a 4000Kv motor in it. I didn't want to buy the higher RPM motor if it had to be run at a lower gear ratio, negating any extra speed benefit. Have you run the system 'flat out' in a buggy with a stockish gear ratio ?
HI!... It's o.k I didn't take it as a dig. I've also got a EZ-RUN 5.5T 6000KV motor in a Tamiya Dark Impact. IIRC it went like 40-45MPH top speed. I did a pinion/spur gear conversion on it with Traxxas gears and no slipper clutch. I hate slipper clutches. lol! 52T spur/15T pinion. That's 3.5:1.
