lost part ! :(
seeking threaded metal steering rod from servo to steering horn ... and also instructions on how to wire in the ledlight unit that comes with the wrangler jeep.......please help...... cheers guys
On a CC01 I assume? You might have more luck posting in the classified section.
Or pick up some M3 threaded rod and make your own, gotta be cheaper than a new part.
true .but i like things to be original....... i have enought grief at work with trucks having to cut and shut bodies and god knows what at work to make things fit .......im looking for the easy way out this time ..
The LED Unit plugs in between the battery and the speed control from what I remember - it should have a male/female 'pass-thru' connector - the battery goes in one side, the ESC the other
Then, just plug the LED leads into it - they stay lit all the time on the Wrangler kit, so if you plug them in and they light up, you done it right!
Edit;
I changed the connector on mine, but this might help;
Battery power goes to top left
more here; http://www.tamiyaclu...484&hl=wrangler
Part you need is part number BS2 in the manual. It's a 3x32mm threaded rod. It comes in the shaft bag part number 9415009. As I type this there are two on Ebay, just search for the part number. You could of course as others have said buy a length of threaded 3mm rod and cut it to suit. B&Q sell 3mm threaded rod.
You would also need the two end connectors which are part D2 in the manual. These are commonly available on Ebay.
acprc .........you have just made my xmas bud..... .. thank you very much .... and mr crispy .... thank you aswell tho... that was going to be my next option .. cheers guys
You are welcome, for future ref the manuals are available on the site.
