motocrosser 1 Posted December 18, 2012 Hi all! I need help to identify this "Limited Edition items" part. It must be a part for F350? Can you help? Thank you Dan Share this post Link to post Share on other sites
TIMECMDR 1 Posted December 19, 2012 <p> Hi all! I need help to identify this "Limited Edition items" part. It must be a part for F350? Can you help? Thank you Dan Hi I believe this is a mounting kit which was produced when Tamiya re-released a limited run of the Mountaineer body set (49457 is the kit number). This is a limited release event only item. This mounting kit enables you to fit the mountaineer body to the Ford F350 High-Lift type chassis I hope this helps. Thanks T Share this post Link to post Share on other sites
djmcnz 203 Posted December 19, 2012 Hi all! I need help to identify this "Limited Edition items" part. It must be a part for F350? Can you help? Thank you Dan The included instructions would provide sufficient indicators no? Share this post Link to post Share on other sites
motocrosser 1 Posted December 19, 2012 Thank you! Now I found another picture here. http://www.tamiyaclub.com/showroom_model.asp?cid=64762&id=3338 Share this post Link to post Share on other sites
