AndyjcClod
Tamiya F350 whats hopups and led sizes?
Hi All
I want to put some lights in my Taiya F350 but I can not afford the light\sound set for it so I am planning of getting my own LEDs from maplin or ordering some of fleabay.
Does anyone know what LED size I need to get so they fit nicely into the existing light points?
Also what wheel\trye upgrades can you recommend to make this truck look a bit more bad boy offroader :)
Headlights and tail lights should be 5mm.
Indicators will be 3mm.
Thats all i can help you with im afraid, im sure some one else will be more thorough.
Depending on what radio you use, you might be able to use the sets Hobbyking Sells. Only lights, but a fair bit cheaper than an MFC (MFU ?)
Tail lights are 3mm (I had to drill mine out for 5mm LED's)Here is m F350 build thread - has quite a few upgrades..http://www.tamiyaclub.com/forum/index.php?showtopic=68426
