I think that was all of them that disappeared. Things have moved on since photobucket but it seems I can only add five photo's to a post If I save  and refresh between each one.
This was my idea to overcome the stripped thread on the gearbox but does it look too much of a bodge ? I've also discovered a stripped thread on one of the front suspension towers.
I've made a start on the gearbox casing. I used wire wool on it as mentioned on a few other threads but I'm not sure I like the results. What do you all think ? I think it's a bit too shiny. I kind of wish I'd left it as it was.
And as for this side, there's not much chance of getting in those recess spaces on the sides. I've just cleaned the edges if you can see.
21 minutes ago, Grumpy pants said:
All looks great imo, I’m pretty sure I’ve read before that the metal is a cheap pot metal and it dulls with age anyway -
@kevtherev will know the best way to get a long term result and if it’s worth while.
Thanks mate, I appreciate that. I have heard it's not Aluminium as we might think, as you say a cheaper metal.
Short of shot blasting it I can't see how to get in the nooks and crannies with the wire wool. I know some of it won't be seen behind the gear casing etc so I don't think I'll worry too much about the sides.
I'm thinking now not to wire wool the front suspension parts, just go with a good clean without abrasives.
On 1/27/2013 at 3:24 PM, mk4savage said:
Hi All.
I got this off Ebay last week with the intention of a rebuild. I bought a nice Scorcher last year which has been built to a very high standard so the idea was to build one of my own to run.
Here it is as I got it, It's a bit of a wreck but is mostly there so I thought.
A bit of positive camber !
Broken front wing, The piece has been stuck on with tape but at least most of it is there. Anybody know what the best glue is to use to repair this ?
The Chassis.
I did notice that these front suspension towers have got small screws where the springs locate at the top. Others I've seen have small lugs as part of the casting ?
The Guy who sold it has owned it since 82 I think he said, Early 80's anyway and he and his dad built it on his 15th birthday. I must say it seems to have been built very well, I have now stripped it and all the screws seemed to be correct to me.
More photo's to come, As I said it's now in a million bits !
Cheers,
Matt.
Looks perfect
9 hours ago, Exit13 said:
Looks perfect
Thank you 👍 I'm going to leave the body as it is as I think it has character. As I remember the white isn't paint, it's the actual plastic that you see and the blue has been brushed on. Not a mint example but I like it and it's how its previous owner had built it. I like the history.
I will try and repair the broken piece and perhaps replace the missing light lens on the front but I think that's it. It'll look ok on the shelf 🙂
  • 2 years later...
Small update:
I've decided I don't like the appearance of the gearbox casing. That and that fact the thread has gone on one mounting point I've made the decision to replace the casing. Managed to get a replacement which should do nicely.
Whilst going through the box of parts yesterday I've discovered that a replacement front arm I bought, new old stock isn't the correct part. It's slightly thicker than the original one, and there's me thinking I'd got a new one 😆. I then did an internet search (not sure where I'd read it)  and found out a few other differences between the MK1 and MK2. The front arms on the MK1 are the skinny ones whereas the one I've bought is for a MK2. I had previously bought another replacement also new in the pack but the thread had stripped on the grub screw. I had to drill it out and re tap it with a 3mm. This one is a skinny one incredibly. It should do the job but I'd hoped I'd replace it with a better one. Never mind eh..
Another difference I found out is the radio box lid doesn't have little breather holes in it on a MK1 whereas the later re re ones have little holes. I hadn't noticed that but have now lol.
This MK1 is going to be a pain in the butt I think 😢
On 1/28/2013 at 10:15 AM, SRB Bloke said:
I'm sure every TC member will remember the same breaks
Yep - that antenna break is everyone of us reversing into a kerb :)
Nice original find.
11 hours ago, casethejoint said:
Nice original find.
Certainly was. I've not seen one like it for sale for a while. Yes there are a few vintage ones but they've all been restored or messed with. This one was as original as you could get, well used and worn out 😆
I sometimes wish I hadn't dismantled it but on the other hand I think it needed a strip down and inspection and replace a few of the broken bits. It's certainly had a thrashing in it's earlier days.
As mentioned I bought a replacement gearbox casing to replace mine with the stripped thread. I also bought a second gearbox to rebuild as a spare or maybe another project, you never know !
Something interesting I discovered between the two castings. The first image is the first one I bought which is identical to my original one. The mounting point has an extra bit cast into it to make the thread deeper. The second image is the second one I've bought which hasn't got the extra bit so the thread is shallower. Both are MK1 casings with lugs on the rear cage mounting point.
Anyone come across this before ? I can only imagine the one without the extra material is a very early one and they changed them later on probably due to thread stripping ?
  • 4 months later...
Well, finally the re build has started. There was a bit of a delay as I was still collecting a few bits and pieces. I read on another thread that someone had re built one using the original plastic gears and they stripped due to brittle plastic so decided on some re re ones as a replacement.
I've uploaded a couple of photos of the progress so far. The gearbox is the third one I've bought as I couldn't settle on the first one (The second one I'll keep as a spare). For some reason the two halves looked different colours as though they were from a different casting. Not sure why as I've seen others like it. I found it was really noticeable but this one is better. It's also slightly better underneath too, no scrapes on it. As you can see, new bearings and gears installed, seems nice and smooth.
I've installed the two bearings in the rear arms but the inner ones keep sliding out down the driveshafts. What do you think I should do to prevent that ? I'm wondering if a bit of threadlock might hold it ? Don't fancy glueing them to be honest.
One other thing, the motor has two ceramic disc capacitors (472) but one has disappeared. How important are these ? I just need to know if I need to replace it. They're soldered across from the wire terminal to the body of the motor. Cheers
