Thanks, but a little confused. What I mean is if I buy the Land Cruiser kit, and want to fit a Unimog body after will it fit using the same body posts?
Unfortuntely, the same body posts won't work for both bodies. If you want to start your RCing day using the Land Cruiser body you'll need two work your way through four screws and a different pair of body posts to use the Mercedes Unimog body in the evening. Believe me, it is not hard, nor expensive. ;)
How is the unimog mounted on a CC01? Reason I ask is I had a Landcruiser which has the standard high rear mounts to reach up to the roof. But you can use the Pajero mounts that reach out to the rear tailgate area instead. Just means drilling 2x 5mm holes in the back and moving the mounts on top of the chassis tub.
