Desert Truck with brushless power!
The CARSON Desert Warrior Brushless Waterproof Pro is a top-equipped, 4WD Desert Truck for desert rally fans. Many profesional features, such as heavy duty aluminium oil pressure shock absorbers, Allen screw set, the water-proof 2.4-GHz LCD RC system “HV” and the 12T brushless combination, also water-proof, make the 4WD buggy a power machine, even under the toughest conditions. On the rollover cage there sit four authentically modelled, bright LED flood lamps. The ready-to-go assembled Desert Warrior XL Brushless Pro is fully equipped with a 2S LiPo power pack with quick charger and transmitter batteries. 100-% RTR and 100-% Rock ‘n Race!
Scope of delivery:
ready-to-go assembled model, 2.4-GHz LCD radio control system, LiPo power pack with balancing quick charger and transmitter batteries
Technical Details:
• X10ET-XL chassis
                • 12T brushless set water-proof
                • all-wheel drive (4WD)
                • ball bearings throughout
                • aluminium motor mounting
                • 12-mm aluminium, hexagon wheel drivers
                • adjustable, heavy duty, aluminium oil pressure shock absorbers (knurled nuts)
                • glued High Grip Desert Truck wheels
                • stabiliser fore/aft
                • camber adjustable fore/aft
                • front track adjustable
                • central, aluminium main shaft
                • complete, set up and road ready
                • 3-channel remote control system Reflex Wheel Pro2 LCD 2.4 GHz "Marine"
                 with Fail-Safe/BEC
                • Reflex Pro2 receiver, water-proof
                • CS-6 MG steering servo, water-proof
                • 2S LiPo power pack, 7.4 V / 3000 mAh 25C with T plug
                • 2S/3S LiPo Compact balancing charger with 850 mA charging current
The charger will charge a 3s.
S l o w l y at 850mA
RRP quoted as 389.99 euros, about £325 at todays rates. Think they'll need to be looking at more like £275 to attract sales away from the already established brands
I like the look of this . Add some alloy sheet panels rather than the lexan and get rid of the wing . Give it a nice cammo paint job . Few jerry cans , roof mounted 50cal ect ect . Could make a hard as nails modern 4x4 FAV type buggy
Wow, I just bought one of these. Check out my showroom. My model is branded as Caster Racing. It has a list price of of £200. At Chinese New Year the car without battery and charger was £120. There are a couple of differences - the body panels, the front bumper (comes with two fitted LED lights), and the position of the receiver. Everything else looks the same.
Boy's a genius :lol:
I saw it on the Carson first and it bugged me then but there wasn't a battery there to make it obvious enough to work out for meself :ph34r:
Wonder if there's spacers on the right side to stop the body being 'lopsided'
An Axial Exo clone that's cheaper RTR brushless than just the Axial kit alone... what's not to like! :D
Been looking around the web but I haven't found anywhere that has then for sale yet. Anyone got a link?
  • 8 months later...
These are finally on eBay, in the UK RC Geeks have them for £400 incl p&p
http://bit.ly/HOzsNP
Or £250 from Modellbau Germany
http://bit.ly/1ftYtJc
If you really love a bargain Modelsport also stock them. They advertise a "Reduced price" from the RRP of £425 and they've managed to crank it all the way down to £424.97... plus post. Now don't blow those 3 pennies all at once folks :)
Mr. Crispy, These are in Taiwan Ebay for 6,999 NTS (New Taiwan Dollars) that's about 145 UK pounds. Worldwide shopping I'm guessing about 30-35 UK pounds. (I know sending a Rough Rider from Taiwan to the UK is 23 UK pounds)The box for this truck is larger than the one I used to transport the Rough Rider. Ref Batterys, I use lipo's or my regular stick packs from my Tamiya cars. Access to the front most battery fixing pin is tricky with body panels in place.
