Can anyone shed any light on this small ESC. It also has an M on it like the M-tronics M. It only has forward. It actually works well and I have recently sold the truck that had it in it and have undertaken to find out what it is and if I can locate a set up sheet for it. It was in an Kyosho EP Spider so is probably 20 years old. Thanks in advance
post-10890-0-23459000-1365289703_thumb.j
hi,
it is indeed an Mtroniks digi dash , not sure if you will find a manual for it online as it almost pre-dates the interweb , your best bet is try emailing Mtroniks and see if they can supply any info , if memory serves i think the pot is for punch control but i could be wrong,it may even have been for drive frequency adjust!
i do remember it was a pain to set up, you needed the reflexes of a scalded cat to hit the set button at the right time , i wasnt lucky enough to have one but a mate did , he cursed setting it up but it was a good esc , made his ultima buggy shift.
good luck with hunting down any info
