I've got one of these on my Xtreme and it has worked well for about 3 years with modest use.
It is now getting very hot and cutting out after about 5 minutes use and with a minimal reverse speed.
In fairness to Tamiya I took it to the beach without protection, so it is very likely sand and water have eked there way in.
Is it toast or a serviceable item?
The cover doesn't appear to want to come off, I haven't used the set button yet as I though this was for turning reverse on and off.
Thank you!
The cover will come off but its a snap fit with the tangs on the sides - chances are you'll make a mess in the process but you have nothing to lose I guess, you may be able to see some dirt ingress/corrosion that may be repairable, or cleanable with electrical cleaner.
Here's a TEU-101 instruction sheet for info - may be worth running through the options before you pull it apart..
http://www.zonacrawling.com/ManualTamiyaTEU-101BK.pdf
and before all that check the drivetrain for any restriction/binding - extra strain on the drivetrain will throw the thermal limit on an ESC
Thank you Percymon, I'll open it up later on after nosing through the instructions.
There is definitely no bidding, it runs well before over heating and grinding to a stop!
I opened up the case and it had sand in the bottom of it and some the solder points had over heated and blackened.
I replaced the case and it wouldn't work at all!
So all the wires have been stripped for spares and rest went in the bin.
Useful lessons all round, I know how to open up a 101 now and although I should have know better I will next time protect the electrics
when I go near the sand or water.
The Mtronix range from Modelsport are worth a look mate - 100% waterproof and reasonably priced .
