I am a happy bunny :P
Today I have bougth a XC Pajero over ebay.
It is for my dad and I am sure he want's working lights.
Working front lights are no problem but what about tail lights?
Did anybody ad tail lights to his Pajero Metaltop [?] I do not want to drill holes into the body and notice afterwards that it looks terrible [xx(]
Also Beermoker has made some, he dremeled the white plastic out and cut and put little pieces from a crashed real rear car light. Alot of of work but [8D]!
I had those years ago. You can make them really, really realistic and put a lense in, of you can do as I did and put in square red LEDs, orange LEDs, and such. If you use LEDs, you can even have them work as brakelights using the brakelight module...
  • 3 months later...
quote:@Wriggleandgiggle
I forgot completely about this thread :P
id="quote">id="quote">
I had forgotten about this thread too !
I have been really busy working for the last couple of months so I havent done alot to my R/C's.
post some pictures when your done!
Mine has tail lights.
1) cut out the holes... drill and then file them out to the size of the apertures. A set of needle files is best and do it by hand, I wouldn't trust myself with the Dremel on this unless you're very skilled.
2) get some scrap lexan, cut to right size/shape. For the 'bend' around the corner, heat it with a lighter whilst bending and the lexan will bend without folding a white line. Might be easier to bend it then cut out.
3) glue it into the apertures (oh, paint the shell first [;)]). I used some Testors glue made for model windows, it dries clear. CA will fog.
4) paint the lenses with Tamiya X-bottle Clear Red.
5) mine uses "grain of rice" lightbulbs, can hotglue/silicone them to the sides of the lights from inside.
6) cover the bulb and back of lens with tin foil, glue or tape it.
