Gripper
540 motors & 8.4volts?
Hello
I now have a 8.4volt nimh battery pack, and I want to use it with a Tamiya BZ 23t brushed motor.
(I have a 12t limit ESC, which can handle 9.6volts, so this should be ok).
But, just want to know if the BZ motor is ok to run off a 8.4volt battery??.
I an using this set up in a pretty much stock TT01, with full ball bearings, and metal prop shaft.
On Carpet indoors.
I have given it a go already, and it certainly shifts. But the motor did get very hot after only a short period of time (less than 5mins perhaps).
I don't wanna melt anything! - is this set up ok?
Kind regards
Ross
If the motor is getting hot, stick a smaller pinion and or a larger spur gear.
The motor will take the extra voltage, but with the above modifications.
+1 on the gearing
Don't forget as well running indoors (racing I assume) you will be accelerating harder and braking harder (from increased power and top end speed), so the motor will naturally work harder and generate more heat anyway. I run my Jugg2 from an 11.1V LiPo on silver cans with the standard gearing for a 7.2, and if I'm just blasting around at full throttle most of the time with no hard braking the motors hardly get warm.
Hello guys
Thank you for your replies.
Ah Yes! - gearing - i will look into this...
And sounds like 8.4v is fine to use.
Thank you
Beside changing to smaller pinion / bigger spur, motor would benefit from some cooling, preferably heatsink with fan
I used a 380 size motor on 2S lipo, stock no heatsink would most likely burn in 5 minutes, with heatsink and fan it's still alive and well after 45 minutes
Also watch esc temperature
