Peachgrower 2 Posted March 4, 2015 My kids and I have been following this build!! We are in the middle of forestry country in SW Arkansas. We are covered with logging equipment around here. Awesome job!! I would call you more of a "real" inventor than a mad one! Could you pack the tires with foam to help with the compression?? Now you need to build a log loader to pull around on the back of a Globeliner or the such! 1 Share this post Link to post Share on other sites
MadInventor 3884 Posted March 8, 2015 My kids and I have been following this build!! We are in the middle of forestry country in SW Arkansas. We are covered with logging equipment around here. Awesome job!! I would call you more of a "real" inventor than a mad one! Could you pack the tires with foam to help with the compression?? Now you need to build a log loader to pull around on the back of a Globeliner or the such! Thanks, I might be able to put some foam in the front tires, but I have a suspicion that they have been superglued on so that the wheels don't slip inside the tires................. Bit more progress today, I've made the rear frame that the roller block fits in. I still need to make something to hold it in position though, as at the moment it's only held up by the friction in the mounting joints that attach it to the chassis. The frame is made from 12mm steel box section and 1.5mm steel plate. The steel cable looks nice, but it's nearly 3mm diameter and I've got no chance of winding it onto a winch drum. As others have suggested in another thread, I think I'm going to have to use braided fishing line for the winch rope. I've also made one wheel cover from 1.5mm steel plate, to help protect the wheel rims from damage. 1 Share this post Link to post Share on other sites
Dojo Dave 889 Posted March 9, 2015 Its a real pleasure to watch your project come together. It makes me think you might work for the likes of Roger Hunt building equipment for The John Deere equipment he sells. My family are in Hampshire and Wiltshire, Next time I'm home id love to see your set up. i used to run a Full machine shop. CNC mills and Lathes. May have to go back to the job part time Share this post Link to post Share on other sites
MadInventor 3884 Posted March 31, 2015 Its a real pleasure to watch your project come together. It makes me think you might work for the likes of Roger Hunt building equipment for The John Deere equipment he sells. My family are in Hampshire and Wiltshire, Next time I'm home id love to see your set up. i used to run a Full machine shop. CNC mills and Lathes. May have to go back to the job part time Thanks Dave, I work in software now, but many years ago I had a part time job in forestry. My workshop is very basic, just a tired old warco hobby mill, a couple of vices, and a rotary table. I also have access to a small warco lathe. On with the build I've been working on the winch for the last few weeks, I've made a winch drum and drive shaft, and one bracket for mounting the drum into the chassis. The winch drum is made in 3 parts, a central hollow drum made from aluminium, and 2 side plates made from 6mm thick steel. Massively over engineered and too heavy as usual, but it was the metal that I had to hand . The winch 'rope' is 0.38mm braided fishing line, with a quoted breaking strain of 100lb. No idea if this will be strong enough for what I want, but the seller I bought it from on Ebay also does 1mm diameter line which has 300lb breaking strain. The mounting bracket is made from 15mm thick aluminium plate, I needed the thickness in order to get the mounting bolts where I wanted them, the bracket will be bolted to the main rear bulkhead and the floor, to stop the winch ripping itself out of the chassis. The drive shaft the winch sits on is 8mm steel, and will run in 2 16x8x5 roller bearings. The drum is driven by pin through the main drive shaft, which sits in a recess in one of the steel side plates. The plan on the winch is to have the gears on the opposite site of this bracket (where the steering isn't in the way), and have another 540 mounted behind the drum to drive the winch. I just ordered the motor, which comes with a 139:1 reduction box, and also the gears to give it a further 4:1 reduction, giving the winch a total reduction of 556:1, which should give it fairly good pulling power on 3S. 1 Share this post Link to post Share on other sites
MadInventor 3884 Posted April 11, 2015 I've got a bit further with the winch. As usual, it's taken me a lot longer than I thought it would. When I tried the mounting block above in the machine for size, I didn't have the cab fitted as I was in the middle of fitting the wiring for the winch. Once the cab went back on, I found that the main drive gear fouled on the cab at full left steering lock, so I had to reposition the winch drum. This meant that the mounting block above was now useless. So, I plodded on with building another one. I've now got the new one done, and also the block for the other side, and am about half way through building the gearbox: Nice new symmetrical right hand mounting block. This one will only be secured to the bottom of the hull, but I'm going to use M4 bolts for a bit of extra strength. The left hand block has been recessed to give me room to fit a manually operated dog clutch, so that I can pull out the winch rope by hand. I didn't want to have to wind the rope out with the motor. The tight fit of everything is evident from the photos, I was only just able to get everything in The motor connections are very close to the hull side, I think I've got 1mm clearance. Still, fitting 1980's radio gear into hotshots has been good experience for cramming stuff into a small enclosure Share this post Link to post Share on other sites
berman 5315 Posted April 11, 2015 Just so impressed by the immense stature of this thing, everything looks bulletproof! If all else fails I bet you could plow this beast through forests at wide open throttle and it wouldn't bat an eyelid lol. Love it Martin! 1 Share this post Link to post Share on other sites
MadInventor 3884 Posted April 26, 2015 More progress: Making the hex drive for the clutch from round bar: Main drive shaft with hex fitted, main drive gear with dogs fitted, and the clutch mechanism machined from delrin. It was quite a challenge to machine the internal hex... Side plate to support the drive gears. A lot of hours went into this. There are roller bearings on the opposite side to support the gear shafts. Clutch engaged: and dis-engaged. It operates smoothly and easily, which is a relief, as I was concerned that it might drag and not slide smoothly. Overall view: I've nearly finished this now, just waiting on some stronger winch rope to arrive and I can fit it in the model. The only thing left to do is either machine a plastic dust cover for the gears, or see if I can get one 3D printed. However it will work fine without it so I'm now going to press ahead with the wiring to get it working, and then I've just a couple of brackets to make to hold the rear winch arm in a solid position, and some strengthening brackets for the cab, and it's more or less finished. I'm going to try and get it finished before August this year, and then it will have taken less than 2 years to complete. 1 Share this post Link to post Share on other sites
MadInventor 3884 Posted May 24, 2015 Test run: very pleased, apart from the wobbly rear wheel where I didn't have the wheel nut done up 4 Share this post Link to post Share on other sites
Yonez 180 Posted May 24, 2015 That is ridiculously powerful, fantastic! Share this post Link to post Share on other sites
MadInventor 3884 Posted May 25, 2015 That is ridiculously powerful, fantastic! And that's only 3S, the main motor is capable of handling 6S 1 Share this post Link to post Share on other sites
Kevin_Mc 411 Posted May 26, 2015 Unbelievebly good Martin - wow! Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted May 26, 2015 Wow, that's looking really good, Mad! Lots of torque, scale speed, metal construction -- all very good! Share this post Link to post Share on other sites
MadInventor 3884 Posted June 8, 2015 A couple of final pictures of the skidder. It's more or less done now, the only item left is to make a small bracket to mount the speed controller for the winch motor (a HobbyKing 1060ESC) I managed to get a gear cover 3D printed, the clutch engage and disengage works well. Just a few more shots of the finished article. Steel gears were supplied for this build by HPC Gears (www.hpc.com) 540 motors with bolt on reduction units for the steering, blade movement, and winch power were supplied by MFA COMO Drills (www.mfacomodrills.com) I'd also like to thank everyone who supplied me with materials and cutters for this build, you know who you are, thanks very much, and also major thanks are due to Mike for designing from scratch and building the custom steering controller module that transformed this from an unwieldy beast into a very tame and easy vehicle to drive. 7 Share this post Link to post Share on other sites
ChILd_ReBoRn 34 Posted May 11, 2019 awesome build.. but.. where's the "grapple" part of the grapple skidder? This is (albeit awesome) a winch skidder Share this post Link to post Share on other sites
MadInventor 3884 Posted May 11, 2019 9 hours ago, ChILd_ReBoRn said: awesome build.. but.. where's the "grapple" part of the grapple skidder? This is (albeit awesome) a winch skidder It was originally going to be a grapple skidder, then I found that the mechanisms I would need would be too complicated / weak for the available space, so went the winch instead Share this post Link to post Share on other sites
ChILd_ReBoRn 34 Posted May 12, 2019 never dabbed in hydraulics? With enough funds.. one can make marvels.. Share this post Link to post Share on other sites
MadInventor 3884 Posted May 12, 2019 12 hours ago, ChILd_ReBoRn said: never dabbed in hydraulics? With enough funds.. one can make marvels.. Didn't have the funds  Share this post Link to post Share on other sites
MadInventor 3884 Posted April 12, 2020 I blew the dust off this model a while ago, and took it out for some off road. I had a few issues with it, the main ESC kept cutting out, and one of the rear tyres ended up with a gash in it, but I did have a lot of dun driving it, and so a few days ago I had a go with it in the garden: It was still cutting out, so I thought I would take it apart and investigate. I'd forgotten what it looked like inside. There's 3 motors in this picture, 2 540s for the steering and blade operation, plus the 5674 main motor. This shows how tight a fit some of the stuff is: I found that I'd mounted the main ESC in sideways, so thought it might be overheating. I decided to mount it in the normal orientation and add some cooling vent holes. chopped up some old sieve and painted it black: I also wanted to add a vent in the bonnet, but the exhaust was in the way. So the exhaust was pulled apart to re-ure what I could, I was surprised to find the branch deflector and exhaust weighed 157g on their own, so decided to bin the 8mm solid rod branch deflector and use 10mm steel tube instead. I also replaced the silencer (which was brass) with a bit of thin wall steel tube and aluminium, and got the weight down to 107g. I also added a vent in the bonnet, for the ESC to suck cold air in through, and pocketed the underside of the bonnet, as that weighed 92g before I machined it. With the vent and the pocketing, it was 71g afterwards. It seems to run ok now, no cutting out, but I now want to attack the back of it to resolve the issue with tire being split, and the back end is way too heavy. The winch on it's own is 1.2Kg at the moment ........... Â 3 2 Share this post Link to post Share on other sites
MadInventor 3884 Posted April 19, 2020 Done some more lightening, this bracket is used in the steering mechanism, I shaved some metal off around the edges to save a few grams: I also machined about 30% of the metal out of the rear bulkhead: I think that the ripped tire was the result of the butt plate sticking into it when the tire distorted, so I decided to elongate the rear chassis to move the plate further away from the rear tires. This involved making 2 new rear chassis plates: This pic shows the difference in length between the new chassis plate and the old one: Now there is plenty of clearance between the tire and the plate I also made a bracket out of aluminium to tie the butt plate to the floorplan and the chassis side plates, as well as having tapped holes to screw the tow bar into. Bracket in place at the bottom of the chassis: and lastly, the plate in place, along with tow bar. Plenty of clearance and I rounded off the bottom corners of the butt plate just to be sure. 6 Share this post Link to post Share on other sites
mongoose1983 3335 Posted April 30, 2020 What a fantastic piece of work. Hat's off to you, mate. 2 Share this post Link to post Share on other sites
MadInventor 3884 Posted April 30, 2020 Here's a bit more of an update.... I've re-engineered the frame that holds the winch roller block. It was originally quite a heavy duty item which self supported itself, so I cut it down a bit to lower the height of the block, and re-used parts where possible to make it flush with the top of the butt plate. I think it looks a bit more functional, and there is less leverage on the whole thing as it's closed to the chassis frame. I also added two 4mm track rods to stiffen and support the A frame. Well, I say me, my son cut the threads on the rods for me . His age is still in single figures, so very pleased he did a good job on it and there are now parts he made on the model. (He also made a couple of parts to go on the War Rig when I was making the bodywork for it ) I also moved the diff lock servo to a new location, was a bit of a squeeze, but it means I can move the whole winch assembly backwards towards the rear axle a bit to help with the weight distribution. I know on the real thing you want as little weight as possible on the rear axle, to allow capacity to support heavy loads on the winch, but I have to make a few comprises as I can't get forestry grade 1/10 tires to properly support the model's weight. Unfortunately I've had to remake the plate I used to mount the servo, as at full throw it hits one of the new ball joints and the diff lock doesn't engage properly, so I've nearly completed a larger plate that moves the servo closer to the centre line of the model. and finally, looks ok from a distance: So, just a couple more minor pieces to make, and then it's just deciding what to do with the 1.2Kg winch assembly..... 5 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted April 30, 2020 I was feeling good about making a rear skidplate for my Wild One today , then I saw this 1 1 Share this post Link to post Share on other sites
MadInventor 3884 Posted May 22, 2020 I finished the mods to this now (For the time being) This is the old position of the winch: And this the new position. Should give better weight distribution. I also rebuilt the winch drum and used more aluminium components, and took some excess metal out of the steel components. I also shaved excess metal from the aluminium mounting blocks. Managed to get the weight of the winch assembly down from 1200g to just over 1000g, so a significant improvement. I also 'repaired' the ripped tire. This was the damage I stuck bicycle repair patch over the worst of the rip, but it looked very ugly. made a slightly better job of this one. Doesn't look very nice but it's a practical repair and saved me having to bin 2 wheels and tires (The tires are glued onto the rims). All assembled up now, and with the weight reductions the front tires don't compress as badly under it's own weight now, so it was worthwhile making the changes, and with the extended rear end I shouldn't shred any more tires.  1 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted May 22, 2020 5 minutes ago, MadInventor said: Doesn't look very nice but it's a practical repair and saved me having to bin 2 wheels and tires (The tires are glued onto the rims). Improvise , adapt , overcome , as Clint said . 1 Share this post Link to post Share on other sites
