europro975 75 Posted December 2, 2013 I know this might of been asked before, but has anybody found any other tyres/tires that fit on the Hilux wheels? Be it Tamiya or an after market company?? Antony Share this post Link to post Share on other sites
Shodog 1835 Posted December 2, 2013 Quite a few 1.9 tires work but you have to use one with a small outside diameter Share this post Link to post Share on other sites
njmlondon 570 Posted December 4, 2013 I have discovered that 1.55 RC4WD tires fit perfectly. The Hilux wheels are actually slightly smaller than 1.9 and they slope away from the rim, so it is hard to get 1.9's to snuggle nicely. RC4WD make several 1.55's with an outer diameter of between 90mm and 95mm. Blazing Blazer tires have a 95mm to give you some idea of size and I think the original Hilux tires were 88mm. I have these on my Hilux... http://store.rc4wd.com/Mud-Thrashers-155-Scale-Tires_p_219.html. Look fantastic and are so much softer than the originals that you actually get some articulation! Share this post Link to post Share on other sites
WillyChang 1814 Posted December 5, 2013 do you still bother with the plastic cage innertube? Share this post Link to post Share on other sites
OldSchoolRunner 116 Posted December 7, 2013 do you still bother with the plastic cage innertube? Good question! OSR Share this post Link to post Share on other sites
OldSchoolRunner 116 Posted December 7, 2013 Not to hijack but what about tires for the Blazing Blazer? Any suggestions there? Jay Share this post Link to post Share on other sites
WillyChang 1814 Posted December 10, 2013 Not to hijack but what about tires for the Blazing Blazer? Any suggestions there? Jay taller tyre carcass is from Wild Willy M38, rim is same size just wider so it'll be 1.55" Share this post Link to post Share on other sites
njmlondon 570 Posted December 10, 2013 do you still bother with the plastic cage innertube?I did try keeping the cage and then trimming the inner foam that comes with the tire. It worked but did not really feel right. In the end I pulled out the plastic cage and used the full foam rings. I like it better this way.The Blazer tires are the same outer diameter as these. Look at the RC4WD tire range... there are several 1.55 options that work really well. Share this post Link to post Share on other sites
