Can anyone recommend me a 3s lipo that will fit the m03 or dt01 chassis? the length isn't too much of an issue as I can fabricate some battery holders as long as i can slide it in. Too small is also not an issue as i'll find something to pad it out with. Ideally hard-case and ideally from hobbyking cheap as poss. Equally if there is a 2s of similar size. I purchase a few options but they don't quite fit and are now in other cars.
Wow, are you sure you want to use 3s with the DT-01 or M-03?
I'm not talking about the sturdyness of chassis and gears (they might both withstand such abuse with ease), but I can't imagine them being controllable on 11.1 Volts.
I have no idea if there are ANY stickpack-shaped 3s LiPo packs - my guess is there aren't.
3s in the DF03 is a handful off road,too much throttle and its end over end.On road its still a handful,just less expensive on parts!
In a DT01 my money is on you not even getting close to full power before its tumbling.Dont get me wrong,its fun having stupid amounts of power. :)
