Hey guys I have a rere Bruiser that I converted to a Mounty. I run it often and the only thing I want to change is the stiff suspension. Is there a way to soften the suspension with out removing the springs which would effect its ride height? Anyone try softer shock oil? I know it is a rere but all of the 3speed knowledge is here.
Pic for clicks:
The only way you would be able to soften the suspension is by changing the leaf springs. Changing the oils won't help much at all. If you are feeling like a bit of metalworking you could always soften the springs through heat treatment.
Hope that helps.
Is that your own Mounty?
+1 to Mats reply . You need to change the leaf springs . The RC4WD ultra flex springs seem to be the optimum choice .
as above, I have the rc4wd ultra flex on my highlift they are good. but if you want to keep the cost down just run 1 Tamiya spring.
you could always put a lift block between the axle and spring if you are worried about ride height.
ps your mounty is the dogs testicles. :D they should of re-re'd the mounty
Yes that is my pride and joy of my rc collection. Thank you for the compliments. I posted a couple threads about it last year. It now sports the black bumpers, i finshed the interior, and added the TOYOTA windshield decal. I really need to post new pics.
It looks so good, extremely well finished. It makes me want to get my Mounty all painted up.
Thanks again guys, I just ordered up some rc4wd springs, should make bouncing around in the yard easier. Ok here are some pics from the photo thread from last year. Newer pics tomorrow. Thanks again all.
