DaveB
What would you pay..?
Well that didnt change much over the years. ^_^
Very little turned up when I did an Internet search on the motor... I figure it would be a very nice addition to a runner for about the same price as a GT-Tuned motor, or a Super Stock _Z type.
Am away from home for a bit now so wont have much chance to open it up any further.
Google MFA RX15. Or MFA RE 700
Got mine from Howes Models , same as njmlondon
Had 10 minutes so opened them up for a brief look... still visually snap.
Posted Image
Great find :)
Just tried oredring from their online store but I'm getting a Windows warning that my card info wont be encripted if I hit 'continue'? :(
I had issues yesterday with online payment, took 5 minutes to load each page so gave up and called them. 01865 848000
If you want to try Howes Models it is best to call them and ask for a guy called Nick. 01865 848 000.
I was actually due a £75 refund from them and have just ordered 3! I only need 1 of them so am happy to pass the other 2 along to TC members at cost. PM me if you want 1 or 2.
PM'd you..
Trying to order from the mfacomo site this very moment as I need shipping outside of the UK. A bit more expensive, but fast to reply my mails. Will let you know (if anyone is interested ;)
Have received one of these motors today,
from Howes models.
Excellent service, by the way.
I think I will fit this rere motor to my rere Egress, (when I get around to building it)
Ended up ordering 3 of these from Howes. One for my Bigwig, one for my original avante and one for future needs.
Thanks for finding and sharing this njmlondon :)
Nice find,
If anyone wants a NIB never ran real technigold I have one for sale for 125 us plus shipping.
Anyone own a motor dyno that can compare the original with this? Is the wire diameter and number of turns the same as the original?
The instruction sheet that came with the motor says,
Motor Construction:
3 pole,
21 turn balanced armature,
twin ball race,
high quality carbon brushes,
specially machined commutator,
cast alloy end case,
very tight tolerances in manufacture.
Adjustable brush timing.
new powerful ceramic magnets
Motor Specification:
Voltage 6v - 8.4v.
Max wattage: 190.
RPM max efficiency: 22,500 (7.2v).
Current drain at best efficiency: 10.3 amps.
Torque at best efficiency:250 gram/cm
All so lists, that the motor should be run in for 2 hours with no load (stopping if it gets too hot) with a 3v battery
Nice find with these MFA motors. Thing is though, although cosmetically they look like a Technigold, when comparing the specs they look closer to a Dynatech 01R? Which isn't necessarily a bad thing.
So, what's the story with these motors? Any good? Garbage? Comparable to the Technigold? Technituned? Technipower?
Anyone installed in it a car yet and compared it with other motors?
Specs are great, but how about some real world testing and reports from the field.
Motor Construction:
3 pole,
twin ball race,
Voltage 6v - 8.4v.
Max wattage: 190.
The real Technigold was :
Torque at best efficiency ............... 430g.cm (7.2V)
RPM at best efficiency .................. 19,000 (7.2V)
Current drain at best efficiency .... 14A (7.2V)
...according to the original Technigold manual inside my box, and I assume that this was all at 0 degrees timing. Thing is, these days even a 380 sized can brushless can perform as well it seems ;-
...as long as the rotor can stay bonded to the shaft LOL. I still adore the Technigold though. I have 2 of them in great condition and a NIB condition box. How come Tamiya couldn't re-release the Avante / Egress with one though? I mean it's only 28 quid when the kit was a whole load of money! And the motor is apparently still available from Mabuchi!
Regards,
Alistair G.
From MFA's data on the "Technigold" 'substitute' motor RX-15, it says ;-
Nominal Voltage: 7.2V constant
Operating Range 6.0-8.4V
RPM (AT NO LOAD) : 22,500
Current (AT NO LOAD): 2.4A
RPM (AT MAXIMUM EFFICIENCY): 15,600
Current (AT MAXIMUM EFFICIENCY): 10.3A
http://www.mfacomodrills.com/pdfs/Miniature%20DC%20motors.pdf
...these figures are rather different than for the Technigold. Either someone has made a mistake or the figures are measured at the wrong voltage or the motor is not the same wind as the original Technigold. Maybe someone could contact Mabuchi and MFA and see what they have to say about it. For fun I just contacted Keda, Leopard and HobbyWing and asked them for graphs / simulation for their 13T 3000KV 380 rotor 540 can sized motor that I bought for my Sand Scorcher, I thought it was interesting to compare it to the original Technigold.
Regards,
Alistair G.
