This is a blackfoot extreme chassis
with the Vajra body
and the wheels came off the txt2 truck.
I have used extended wheel axles from topcad
E.wheel hub adapter (4) +15mm wheel axle for lc40 15321
just used extended axle then standard wheel hex then the txt wheel mount
I will try running it tomorrow, as long as it isn't raining
Got a little bored after I finished the fox build.
had the vajra shell spare,
found the txt2 wheels that I got cheap,
and rummaged through my junk box and found the xtreme chassis
I suspect it will handle really badly with those large wheels, but it will be fun trying it out :rolleyes:
Took this for a spin out in the garden today
It handles quite good considering it has the large tyres.
kinda handles like a clod, all bouncy :P
Will try to find an 18 tooth pinion as the 20t fitted is making the poor motor struggle on take off.
Could ideally use a better servo as the standard one is struggling to steer
When its moving it turns ok.
Oh the whole I am quite pleased with it
