First one is definitely not a 405 or RS200.... although I can't quite ID it properly.
Third one is an Alpha EP rally car. These came in brown, blue, and black, brown being the first generation. Slightly similar chassis for both EP and GP was available. Not too bad a chassis, as long as you added full bearings and replaced the shocks (which were friction, and the top of the shock had no actual physical connection with the bottom!). With shocks and bearings, these made a fine rally basher.
Hope that helps mate!
Alex
Hi .Thanks for the info . I think you are on the right line . It looks like a mix up of a few models here . The front looks a lot like the Panda 4wd , the wheels are the same too . I can't find the upper deck on the Panda manuals so it might be from another model , but thanks again for your help - much appreciated
That looks like it - looks like the wheel covers are missing but the upper deck is the same , as are the front arm blocks and chassis shape etc - thanks again for the info :)
