Hey Percymon, how did you get you RPM Revolvers to fit? It seems the inside rim hits the car. I do not have the hex adapters yet but just putting the wheels on, it appears I need a longer axles?
I fitted the hex adapters (ca 15mm long at a guess) and just dropped the revolvers on. I think there are normal and narrow versions of the revolvers, not sure whether that means the rim width or the overall track width once fitted. ( ie offset)
  • 7 years later...
On 4/9/2014 at 2:38 PM, Toykid said:
I used the Tamiya frog re-re hex adaptor for the rear so I could fit the rear Tamiya hummer wheels and tires. On the front I used the wheels from a kyosho scorpion with the same Tamiya hummer tires but with a section cut out of the middle to make them more narrow. Using tire glue gives a really good hold and the tires stand up to a lot of abuse.
Posted Image
@ToykidI'm not sure if you will see this but if so can you tell me where you got the front light bar? It's perfect for a project I'm working on.
Mr Toykid has likely moved continents thrice since that post :rolleyes: and i've recent suspicion he's now stationed seriously close to moi :ph34r:
He's the brains & brawn behind Knight Customs btw, likely one of his own designs :P go check it out
https://www.shapeways.com/shops/knightcustoms
Thanks @WillyChang. Yes, I am aware he’s behind Knight Custons but I actually didn’t find that lightbar on shapeways, though I might just have missed it of course. I will take another look.
I see you are based in Victoria, same!
shoot, U r too :)
Heard word of Vintage Bash tabled for October???!??
https://www.facebook.com/groups/358809129010528/?ref=share
Come to think if it, 2014 he was just starting out. That WildOne would’ve been an early effort, maybe not even DIY printed bits :blink:
Early on I think he used a fair few bits off Axial SCX10 etc ; who else was in the early crawler market?
6 minutes ago, WillyChang said:
shoot, U r too :)
Yes, I had seen something about that but hadn’t quite digested all the rules/entry criteria yet! I think I might head down just to have a look and take my Egress and Wild One just in case ;) where in Vic are you?
P.S.  sorry for derailing the thread
44 minutes ago, GeeWings said:
all the rules
Rulez?! Who need no stinking rules <_< I just read it as “run what u brung; don’t go blatantly overtaking the old race pros & if u get DQ’d for illegal equipment - who cares!” :P
I'm in the city. Sounds like you’re far out bush?
 likely James Knight could be attending
Lol. Sounds good, if I get a DQ I will say I was following WillyChang’s rules ;)
I’m in Brighton, bayside, with all the other ex-pats ;)
On 4/1/2014 at 8:37 PM, BROKEN NOSE said:
I'm trying to find some nice street tires to go on my Wild One. Do y'all think the street rover tires will fit the wild ones rims? If not, do y'all have some recommendations.
I thought I can give that a go and with some tinkering they will fit the front wheels go straight on the back need the adaptors to be swapped (these street rover tyres & wheels are off my blitzer beetle metallic edition)
