Ok needed batteries that fit the SRB and other vintage chassis
Had a old knackered Tamiya 7.2v hardcase hump was going to fit nihm's but went lipo :)
these look great in my vintage runners
Tools needed are simple
1.Craft Knife or stanley blade
2.Small hammer or pliers
3.Soldering iron
4.Double sided foam tape ( poundland stuff as i went through 2 rolls doing 5 batteries)
5.Electrical tap grey silver or white
6 7.2v Hump pack or 6v stick
7.Lipo 2s 7.4v soft pack
I used these http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=37406
1779818_10153999595625506_89123775089280
1. Run the knife gently along the joint seam on battery slowly work you way round blade should be around 2 or 3mm into case .
10150614_10153999596155506_35260784105091240387_10153999596055506_11387288581877
2.Now gently tap the knife blade through the case starting at the wire end and work your way back round to wires . You will tell when knife has gone through case once you get near end will find case will start to come apart just be gentle and don't force it as they can crack and rip easy
10004041_10153999596310506_198831216907210172750_10153999596480506_8404195521099
3. Now case is a part you have to remove the small tabs in the top and bottom of case . There are 4 very small tabs in the middle of the bottom case I removed just as a bit of OCD was a bit worried if I fitted bigger lipo mite poke through foam tape and go into lipo
10170772_10153999596585506_23015117330691888596_10153999597180506_46139329187634
4. After washing and cleaning off 25 years of marks on cases time to fit the lipo :)
1475774_10153999598685506_54881836676841
5. Make the wire holes bigger and test fit . I used a dremel but was very care full as one slip and that's and hour of work gone
1959475_10153999598675506_2412672107808010150813_10153999598915506_3812713345477
6.Now apply foam tape double layer on bottom of battery . Three layers on sides and wire end of battery and double layer on other end . Have to trim the tape on sides down by about a third .
10001299_10153999599110506_1766425669125
7. Now fit to battery to case only remove backing from foam tape on bottom of battery fit into case . Now fitted remove rest of foam tape backing
10259913_10153999599160506_576295512626310006183_10153999599270506_5291478812673
8. Run a bead of super glue round joint on top part of case and fit and hold in place with cable ties till set
10151808_10153999599375506_7054972911237
9. Remove cable ties and run a bead of super glue round joint let it set for a few minutes . Now run the soldering iron over the joint . Watch out for fumes as the sting your eyes . Then cut off any excess plastic from joint and tape over joint with electrical tape . Found out from testing that this way works well can drop batteries and they stay in one piece :D
10170890_10153999599475506_739592791171210251918_10153999599630506_3064497444467
10. Fit your favourite connector I used Xt60's as that's my standard fitting for lipo's and use deans for nhim's idiot proof well nearly
Now enjoy your vintage look lipo's
I have run them in my Hornet and work great
1621884_10153999599765506_38402792456248
Thanks for reading my waffle :)
looks ace, but unfortunately I have no hump packs 😩. Have you managed to fit any bigger packs in with less packing? Perfectly turns a soft pack in to a hard-case pack too. Anyone got any redundant hump pack cases?
looks ace, but unfortunately I have no hump packs . Have you managed to fit any bigger packs in with less packing? Perfectly turns a soft pack in to a hard-case pack too. Anyone got any redundant hump pack cases?
Could fit bigger was more the price and c rating that got me to use these and i would rather have to much padding than to little
plus run times are about the same as a 3700 nihm pack that are a bit of a squeeze in the hornet chassis around 45mins
Nice job. Old look for a young soul. And I think I can identify with that "Nihm idiot proof" ^_^.
Hope you found a solution for the round case batts.
Shorty lipo's fit in the srb radio box well too, Plus they are usually 4000mah and a high C rating :) If you wanted a vintage look you could gut the shorty and put the cells inside a hump pack as above :)
