Hi chaps.
I'm looking to get a rough idea of what i could charge for my Beetle.
It's got b/bearings, new receiver, new servo, new servo saver and new crystals.
The body is complete with no cracks, although the nose cone has been drilled out and 2 LEDs wired into the headlights.
The body has been crudely painted (by someone else) several times with a brush.
No glass or sunroof.
Chassis is in good condition, although the rear body mountings are missing a section between the 2 uprights and there is slight damage in the centre screw hole just above the front bumper mount.
The MTronik ECO27 esc is assumed dead, but just needs a replacement to get running.
Also with it are the transmitter, a quick charger, 1 x 1200 mah battery and 1 x 3000 mah battery.
Any valuations appreciated.
Thanks,
around the £70 mark[?]
if you could get it running i think it would be a lot more disierable as monster beetle projects dont ever seem to fetch good money[8)]
or you could look at it this way:
rolling chassis is worth £30
body £15
radio gear and bats £20
motor and speed control £10
well thats what i would pay (if i had any money left[;)])
I think the rough price you got was spot on, mind you it could fluctuate up or down about £20...
As for what you spent on it, well I say why not keep it then??
But don't hang on to it thinking that it will go up in value, it might go up a little bit, but I wouldn't think by much.
Well if you don't need the money, just put in a box and forget about it for about 10- 15 years. Then you may get some more.
I might do that with some of my cars now that they are restoerd..
