Hi,
Would the screw pin bag for the Boomerang be the same as the one for the Hotshot? I know the numbers are different but the screw pins look very similar.
I want to make sure because there is a set on ebay for the Hotshot, so I won't bid for them if they don't fit the Boomerang.
Dougan
I would think so, seeing as the front suspension arms are identical, and the rear suspension arms are only slightly different due to the monoshock / dual shock set ups.
One would think most of the contents in the bag would fit, and if not then I think only the two top inner screw pins would be different on the Boomerang, from the Hot Shot.
These two in question are shiny, while the others are black. I have a complete set of spare screw pins by the way, as I replaced mine with new ones. They are a bit dirty and a little rust on them, but they work as they should I just replaced them because I had extras and they don't look real good.
Most of them work for both cars. The hotshot has some really short ones that the boomerang doesn't have.
Jim
Thanks for the info guys.
I have purchased the screw pins, because I really only need the longest ones.
Thanks again,
Dougan
