mr crispy
Fast Attack Hopper budget build
This just gets better and better! - love the new 'fat tyre' look for the front wheels and the bonnet vent is perfect...
It looks fantastic - no wonder you felt the need to stick your Willy in it ;o)
Jx
Jenny! Cheeky minx :)
So anyway... actually Jenny I kinda used an idea you suggested about the padding on the rollcage. I've used some 6mm styrene tubing which I cut to length and slit open to allow me to wrap it around the cage bars. It holds itself on quite tight and only shows a 1-2mm gap where I slit it. I've also bolted on a plasticard roof panel and glued some tabs inside the bonnet to secure it near the roll bars.
Here's the pics.
0F6C2643-2312-46F9-B0F2-208FE85D2293_zps
89DF1880-4857-49BF-B470-0B37B1C3FAD7_zps
461BF8FD-AECA-450C-870B-034EB14B88D6_zps
I had thought the Brat tyres would look too fat atvthd front but the more I see it the happier I am with them. I have already noticed these rears don't have the same amount of grip as the old Hornet tyres which is probably a good thing and will hopefully make it less likely to try to swap ends on loose surfaces.
98CE94E9-E6BC-40EE-B8AD-3213F1358716_zps
Not too much more to do now. I want to fab a spare wheel mount on the rear cage, a fan shroud on the engine and I was wondering about some small panels on the rear end to get a bit of colour back there. I'm thinking to keep the cage bars black but possibly paint the pads yellow. The body will be painted white with yellow detail panels.
Looks amazing Nic! Can't wait to see this in paint now.
Nice work Nick . How about just adding panels to the rear side ' triangles ' as per a Rough Rider ? IMO the front tires look too wide - maybe get SRB Bloke to narrow them for you ? I'am just being super critical though . This does look fantastic .
I was thinking both those Bromvw, but the fat front tyres have grown on me :) I've mocked up a set of rear panels out of cardboard to see how they look. But first I've been fiddling with my rear end again!
Made a fan shroud for the Duratrax engine from plasticard.
7AC14C1D-F4EA-4B28-B2F2-CAAA14E8C7FB_zps
3C528948-0C10-4467-B18C-5CCBA6031E92_zps
And a spare wheel holder from brass strip and an old steering servo horn.
9DE688BF-C2CF-461D-A709-19579013C8E0_zps
CB2F5553-BD39-437A-8070-4EA22620D6BF_zps
It's not as robust as I would've liked so I'll keep an eye on it.
Here's the first try at the rear panels.
C478EA5F-3FEB-44C2-8F9F-D584D0FFE29B_zps
48C73198-54F7-41FB-83DB-6D57D12A3217_zps
I might make them a little smaller when I transfer them to plasticard as they hide the engine a bit more than I wanted. Quite happy with the balance though, it'll need some colour at the rear.
393425B5-2EC1-4BEA-9EA7-CD04B1019B0B_zps
Again my complements on a really great build. It is looking better than ever!
I don't know if this is available in the UK, but I'm using plastic mesh from the craft/fabric store. It was only 57 cents per 26.7cm x 34.3cm sheet. There were lots of colors available. I'm using some for the roof on my FAV build. I've been thinking about using it on some of the triangles as well.
Hmmm I bought some plastic mesh like that a few years ago, I'll have to dig it out and see how it looks. Good find Biz73.
Today I've done the last few modelling mods. First I put together a new WW driver and cut a section out of his back so he sits a little further back. Filed and it's ready for fitting.
D78EAF56-4EE3-4793-BEED-A3E516141EF3_zps
I also added a side peice to enclose the cockpit area a bit more.
E4F09FD3-A511-4832-B5C7-3B5E468C5A0F_zps
And cut the rear panels from plasticard. This side needed a small notch for the antenna mount.
27C6D49A-C2D3-4268-9492-A89D9EC83E88_zps
Other than cutting the steering wheel that's about it!
39FA4013-8EA3-46B0-AAF2-16F12D4109EF_zps
53ED537D-9F6A-4F87-B756-40E1F6E3471F_zps
4D5F0268-728D-49A8-90A5-08414DCF0892_zps
Next job is to strip it down for painting :)
More tinkering today. On the last few runs I found the car would cut out every now and then for no apparent reason and then be fine once I picked it up. Traced the fault to the pressure the battery plug and wiring was put under crammed into the small space so I reluctantly have relocated the ESC. It's now under the driver at the rear of the chassis so I've cut a hole in the cockpit deck and given Willy a bit more of a trim.
BF0D7615-B2D0-4FC5-A897-2B948C5469D3_zps
130595BD-2C62-407E-A9B8-18BDC18CDFD7_zps
It's visible when he's fitted but it's not too bad and I can improve the look but a little more plasticard work and how I paint the driver. I've also taken inspiration for the GH's fixing for the driver and now hold him in place with a self taper through the roof panel into his head.
6F331A43-881E-4465-A90F-457B97C6FE46_zps
Drive it around the garden and it's not cutting out anymore :D
I also got around to trying out the 380 motor in it and I'm quite surprised at how fast it goes.
ESC is much cooler now but the 380 was very hot after 5 mins!
Drop a sport tuned in it mate . Then it will really be a ' Wild Ride ' lol
Mr Crispy, this is turning out great. Now that you have the bigger tires all around, the spare is like those mini ones that come in compact cars today :)
I just finished a FAV build, and would like to use the rx tube mount that you used here. What type of car did this come from? And if you know which parts sprue, I would be grateful for the help. Thanks
Space saver, it's lighter so helps it go faster :D It was all pre-planned of course :)
The antenna tube holder maybe available in other kits but I think mine was from a TL01 or TL01B. It's on the B parts sprue. Follow the link below.
http://www.ebay.co.uk/itm/111126907388
You can see it in the bottom left corner, between the servo spring and servo horn.
Took the FAH to my usual testing area at the local rec ground and it's loose gravel handling is much better with the Brat tyres and 380 motor. I'll keep the silvercan 540 for those total loonasy moments as it's only takes a few mins to swap them.
88D66633-0712-4E44-A24A-517BFEBBE28E_zps
Hope to start painting this weekend.
You can actually keep it in a straight line now on the loose stuff... but where's the fun in that?
Thought I’d update this old thread as the Fast Attack Hopper is finally finished. Traded it with my brother in law and he gave it a rather nifty P51 Mustang paint job!
40D10C16-DF08-4182-9DA9-D77DF6696DB6_zps
26C49593-715B-43CF-B0BA-0004092C5BFE_zps
0868455D-F9AF-46ED-A2CE-E9A7F53A8EA4_zps
I’d like to point out the drivers face was painted by yours truely 😉
D999BF8B-9054-4213-B5D1-7D9289F7ACCD_zps
  • Like 10
That looks brilliant! Makes me want to build another Hornet
This is truly a great build. I have dozens of hopper/hornet chassis's laying around and this looks like the prefect way to bring life back to a forgotten car.  I believe I have every part you used in laying around.
Apologies this was whilst I was halfway through the thread. P51 is one of my favourite aircraft so anything that looks like one is fine by me!!!
He’s done the old girl proud... just a shame he’s too scared to run it 😉
