MASSIVE parts sale TGM02 TGM 03 TGM04
Hi guys, I have a large amount of NIP spares to sell at cheap prices. I will do a good deal on a bulk purchase!
Please check the part number guide in the manual for your model to make sure you get the right parts for your model.
0444291 U parts - shock cylinder $5
0004525 F parts - hub carrier rear $5
0114022 J parts - diff housing $10
9404453 Ring gear bag $5
0004168 D parts - bulkhead $5
9804348 Aluminium damper cap (blue) $5
0440242 upright $5
3454118 clutch bell $5
51024 B parts suspension arm TGM03 $5
7684016 starter shaft $5
9804192 damper rubber $2
9804160 3x12mm shaft $2
0554006 main frame T parts $10
9404698 diff gear bag $10
7684139 FS12SW & FS18S rear adapter gasket $2
51300 TGM03 TGM04 suspension arm set $10
9004200 D parts suspension arm $5
7434004 RS380H motor $10
0444169 shift clutch $5
0444162 uni joint $10
9404776 ring gear bag $5
9415848 roll bar bag $5
7644021 125cc fuel tank $10
0114091 K parts Nitrage diff case & ball end $5
9415854 Main shaft bag $10
9404697 damper parts bag $10
50952 44mm driveshaft set $10
53982 Nitrage stabiliser set $10
9404456 Fuel tank 150cc TNX $10
0114041 TNX K parts $5
3454464 Nitrage joint cup $5
9404694 TNX counter shaft bag $10
51031 TGM03 hard steel pinion $5
51034 TGM03 joint cup set $5
0444145 terra crusher uni joint $10
9334086 TNX starter cover $5
5454008 TNX/TGM04 35T spur gear $10
0444292 TNX/TGM04 shock end $5
0004486 B parts TNX $5
0114090 J parts hub carrier rear Nitrage $5
5404005 TGM02 shift housing $10
9404692 TNX/TGM04 suspension arm parts bag $10
9415859 cardan joint Terra Crusher $10
9804272 TGM04 TNX diff joint cup $5
9804270 TNX wheel axles $5
9415875 TGM02 Terra Crusher clutch pad housing $10
9404455 TNX suspension arm bag $5
3454247 TNX pilot shaft $5
9415856 final gear shaft bag $5
4304014 starter gear plate $10
9415844 TNX cross joint bag $10
no tag TGM04 M parts $10
I have some parts for TNS & TNS-B, not sure on the crossover on these models:
0004291 A parts $10
7684459 throttle arm for FS12FD $5
0114073 hub carrier $10
0114071 K parts suspension arm front $5
0004293 C parts Bulkhead $5
2594035 U shaped shaft $5
I have multiples of most of these items, I can get pics for you for items you would like no problem, but as you can see it would be quite an effort to get individual shots on everything!!
Parts are located on the sunshine coast in Queensland Australia, pickup is great but shipping locally and overseas is no problem.
Cheers, Dave.
