I am trying to get dimensions of the GT01 chassis, but cant seem to find actual measurements other than the body. More specifically this kit http://www.tamiyausa.com/items/radio-control-kits-30/1-12-tamtech-gear-kit-30200/rc-tt-gear-porsche-turbo-rsr-57101
I want to know-
-wheelbase from center of axle to center of axle( front to rear)
-track width front and rear- preferably from outer edge of tire to opposite side outer edge.
I am trying to see if this chassis will work with a 1/12 body I have.
Thanks,
Drew
Any use? http://www.tamiya.com/english/products/57101porsche934/
Specifications
●Length: 355mm
●Width: 168mm
●Height: 108mm
●Wheelbase: 190mm
●Tread: 129mm (Front), 138mm (Rear)
●Tire Width/Diameter: 20/54mm (Front), 25/55mm (Rear)
●Frame: High-strength resin monocoque type
●Drivetrain: Rear-motor, rear-drive 2WD
●Diff. Gear: Ball Diff.
●Steering: 3-piece tie-rod type
●Suspension: Front & Rear Double Wishbone
●Gear Ratio: 10.86:1
●Motor: Type 370
●Speed controller: ESC (not included)
●Endurance: 30min normal running with fully-charged battery pack (not included)
The tread/track will be to wheel-width centres, so overall width will be around 149mm front, 163mm rear (5.87" and 6.42" if you're still working in old money)
Thanks Twinset. That works for me, its odd that the tamiyausa website list no specs on the chassis at all. And my google searching never got me to that page. Appreciate the info.
Might be a 'territorial' thing, but mine had that page as first result;
There's not a lot of crossover between the Japanese and US sites, the Japanese site doesn't list the Rock Socker yet, even though I copied the information from the US site on April 9th
Most of the model info on the TC mainsite comes from the US site, as they seem to be the most up-to-date on the majority of the info that I need.
