Hi,
I'm about to start the build of my Buggy Champ but am getting all the painting and bodywork done first.. just wondered what the general consensus is on the best way to achieve a great finish. Last time I had one of these over 30 years ago I built the car first then sprayed the body with one coat of car paint, slapped some decals on it and hit the driveway - this time I'd like to do a better job!
I've started by sanding the entire body with super fine sand paper, two coats of plastic primer and sanded each coat so its very smooth and ready for paint. My questions are:
- How many coats of Tamiya paint should I use, and do I sand in between each coat?
- How many coats of lacquer should I use, and again do I sand between each coat?
- Do people stick the decals over the top of the lacquer or put them on first and then lacquer - what will give the best look?
Thanks guys...
After doing some body preparation, one thin coat of primer, and two coats of enamel. That does it alright. I've never used lacquer. If you learn to use the enamel, you won't need it.
I've always found auto industry paint to be good for hard bodies. It goes on well, is very hard wearing and has a huge range of colours. I usually do multiple light coats and let them dry for 5mins before applying the next one. I'll do as many coats at it needs to get the colour right. They normally dry glossy so you don't have to lacquer, but if it's a runner a coat of two of lacquer/varnish helps to protect your hard work. It also gives a smoother surface to apply the decals to and get less air bubbles or "grey" patches. I never sand between coats but then all mine are runners so I'm not looking for a glass like showroom finish.
Personally I don't varnish over decals as I figure if needs be I can pull them off again and replace should they get worn or faded.
