8rad1
How to put universals on your Falcon
So. To fit universals on a Falcon you need the following:
Tamiya OP-790 Drive cups for DF-02
Universals for an HPI Nitro RS4 wide. Rear 52mm pin to pin. The axles on the fronts use a larger diameter inner bearing and may not work.
6mm drill bit
In this case I chose MIP 1182 shiny bones.
First you need to drill the OP-790 to 6mm
Then install.
Hi Brad, this is great!!!
Can you post more detailed pictures and a total picture of your Falcon? I see it uses Hi Cap campers.
Max
Here are some more pics for you Max.
Yes you can use my pictures. I actually used your thread as a starting point. :D
Hi 8rad1,
Do you know the size of the pin that joins the shiny bone to the axle? I bought these to do this to my Falcon but they did not come with these pins.
Thanks.
I am not sure. Any CVD rebuild kit for a Tamiya touring car with 5mm axle should work. I will measure the pin but it may be a while before I get my hands on a caliper.
This is a great Falcon imho!
Max
Ahh, good to know. I need a new top and bottom front end parts for mine and spent ages bridging together rear shafts that work. Looks like I have a few more parts to order for my winter rebuild.
