Sign in to follow this
Cavscout
Mystery motor??
It's a Tamiya Dyna Tech 02H. released 30 Nov. 1989.
13 turn. 0.65mm wire. 413g-cm at 25500rpm + 20A
Was standard in the Top Force Evolution and probably other too.
Hi.
You can also fit a another rotor ref. 7013W to get more RPMs.
If you get one just be carefull not to lose the carbon springs. Mine are attached to the endbell.
Emmanuel
quote:
Originally posted by jerzirccar
Best motor TAMIYA ever made.[
:P
Jerry
id="quote">id="quote">
Knowing Tamiya it should be somehting like: The best motor Tamiya ever put his decal on... [:o)]
If it's the best that would explain why my Clio went like stink! [:o] Still, the battery (2400mAh) seemd to last as long as usual! (20-25 minutes!) Could this be true or am I seeing things?
Also, can I put this motor in my Mini, or am I asking for a melted gearbox? [:I]
