Not sure I had it out last year at all honestly.. I used them in the winter of 2012/2013, but got disappointed due to the open Diff
I have 3 in various stages.. the Blackfoot 4x4, my son has a Dual Hunter and my daughter has a Blackfoot with Parma Beetle body.. her si next to be converted to 4wd
I just installed a set of Traxxas shocks rear has white springs and front is red and have no clue which is stiffer
anyway a quick pic of it on pavement
It needs a wheelie bar, I flipped it a couple times
The tires/wheels combo are 2 sets of rears from a Wild Willy 2 ( more recent version)
That are smaller in diameter than the original Blackfoot wheels but I like them better with the narrow stance as well
Yes they do..
I also need to find another body, either a second clod body or a parma body, I like the 53 ford pick up but the wheel base is too short..
Yeah, but I don't like the molded blower on the parma lexan body.. I might get a grave digger or something that is old but cool
Thinking about going back to the wider stance on the truck, I like the narrow look and was trying to get it to look like a scaler, but I think if I went back to the wider look I can drop the body a bit and keep the Wild Willy Tires
Jeff about a year or so ago i built a 4x4x4 Wild Dagger based Blackfoot . It took a lot of work and even more thinking out but i fitted it out with Clod sized wheels . Fusion do some high quality axle extenders if you need a quick fix to get the wide look .
