I have a Spectrum DX4C and an SR201 receiver. After binding them together, motor goes to full throttle when trigger is at neutral. When I push the trigger all the way to reverse, it's as if I let go of the throttle and the motor stops. I tried reversing the throttle channel but then it works the other way around - motor still goes to full throttle when trigger is at neutral, and stops at trigger full throttle! The ESC is forward only type. Does that have anything to do with it? Or is the receiver faulty? (brand new receiver). The trasmitter has been boundto another receiver (on a different model profile) which works fine. Please help. Thanks
Sounds like a case of setting the ESC up for the nuetral and maximum throw points.
What ESC are you using? As usually goinf through the ESC setup as per the instructions for that specific type of ESC will solve the issue instantly.
James
