snippy9 2 Posted July 8, 2014 Hi club members,I have just bought a non running QD Blackfoot which I've now got up and running (by changing the on/off switch.However the controls are reversed ie the throttle operates the steering and the steering works the forward and reverse.Any ideas why this could be?,are QD vehicles made any differently to the kits?I've tried a few controllers and different crystals.Any insight would be much appreciated.I bought this to introduce my young son to Tamiya until he's old enough for a self build.He could use it as is but I'd prefer it if I could get it going as per normal operation.Thanks in advance,gary Share this post Link to post Share on other sites
Wobbleboxer 10 Posted July 8, 2014 Sounds like the ESC and steering servo leads are in the wrong sockets on the receiver, ave you tried swapping them over? 1 Share this post Link to post Share on other sites
waterbok 1282 Posted July 8, 2014 You need the original controller, you can't swap the channels with the original internal electronics as the servo electronics are on the mainboard. They can be replaced though, a standard servo fits with small modifications. Or modify a remote, swap channels. 1 Share this post Link to post Share on other sites
snippy9 2 Posted July 8, 2014 Thanks guys,looks like he'll be using it backwards unless I can pick up an original controller (it didn't come with one) Share this post Link to post Share on other sites
WillyChang 1814 Posted July 9, 2014 Modify the remote, switch the wires between the 2 gimbals. Usually only 3 leads each, so 6 solder points. 2 Share this post Link to post Share on other sites
snippy9 2 Posted July 9, 2014 Thanks I'll try that,got a few spare controllers ;-) Share this post Link to post Share on other sites
WillyChang 1814 Posted July 11, 2014 Some of the "better" old TXes had their gimbals screwed to the case (some could adjust for angle), if you're lucky you could just unscrew & swap over if the wires were long enough. 1 Share this post Link to post Share on other sites
SteveU30 1011 Posted July 11, 2014 Or hold the transmitter upside down :lol: 1 Share this post Link to post Share on other sites
snippy9 2 Posted July 11, 2014 Thanks guys,I'm going down the re-solder route. Steve is that called thinking outside the box? Share this post Link to post Share on other sites
snippy9 2 Posted July 12, 2014 Looks like WillyChang takes first prize,the old Acoms transmitter gimbals are screwed in place with just enough cable to swap them over.All in all an easy fix really,thanks for all the comments,no doubt I'll be back soon with another question ;-) Share this post Link to post Share on other sites
