BEC out probably?
Most of those little fans come with a BEC plug which will happily plug straight into most receivers (supplying 5-6V).
At least that's how all of mine are wired-up, with the exception of the Speed Passion ESC where the fan unit is integral to the ESC circuitry.
The fans I use will take 6 to 8.4 volts.
I like using the battery in on the ESC as I can turn the speedy off but the fan still runs to cool things down while I am marshaling the next race if I leave the battery connected.
You can also use a spare socket on your receiver quite happily if you have one. Especially if your fan needs 6v. This will obviously shut down with the ESC though.
C..
