Yes, these Tamiya 53155:
Those are a tight fit, on the front I had to remove the spring thingies from the shock tower and installed longer damper shafts.
Also used some spacer on the shocktower not on this picture
rear standard length but needed an o-ring
unfinished project I can make some new pics later and do some measurement.
I got the alloy CC dampers coming from Banzai they may a fit too.
Yep, but up front everything standard will be a thight fit or you could try the tamtech shocks but they cost a fortune.
At the bottom is some room to shorten the bit on the lower arm.
Mmm maybe I should start using my mini lath and make me some of these damper parts, now where to find springs?
what are the measurements of hornet spring?
Here you go fella
Posted Image
Posted Image
