There M4 I think.
You could turn up a M5 to M4 adapter threaded stud but I don't see the point really, other than you would not have to thread lock the bolt each time as the m4 is a nylock nut.
J
Yes, I don't really see the point either.
On a side note, I ordered an Axial Wraith interior and will try to fit it. I may have to change the driver since he doesn't have a lower half. Hopefully all goes well!
Pics to follow...
I don't know all mechanical English words what I want to do is make an inner threaded axle inside the CVD axle that exit with a 4mm thread for the nylon nut. This inner axlex will be kept in place by the blue treadlock and the wheel adapter locking pin.
Max
Little update..alloy hubs came in today :)
50AC5A90-11D4-4C34-90F5-C8472836E051_zps
Before:
9F900B93-970D-4EC1-9017-B759BA0037C7_zps
9B3EA0C0-CC12-46B0-9AC5-F5DCB623DFB2_zps
Original hub with shaved stops for more steering:
5A4E1EFB-DC35-43F6-9E62-41E87646FC65_zps
Side by side:
5F4A2552-2396-4AC0-8746-43589E823382_zps
New hub fitted:
2ADA54D0-6EC8-4DDF-B143-FE984EB8EF24_zps
And after:
D4FF2E1E-3B6B-4855-9841-41EFF1DEFDEE_zps
6CC440B8-8F3C-4948-B63B-A6A446836B7F_zps
Definitely achieved my goal of more steering angle with these hubs. They are stronger, smaller, and possibly even lighter than the original plastic pieces.
Just waiting on a few more items and my Clod will be complete. I plan to give it a good thrashing this weekend if the weather is nice. But I'm already thinking about what will be next project :D
Torn between a Trail Finder 2 (though I will not likely defect from Tamiya), a High-Lift, or a CR-01. Decisions, decisions, decisions...
Gave it some bumper mounted spot lights this evening.
I got these from eBay, not knowing they weren't LED :(
2B1E999D-CE44-44BB-8AD1-7C5C3EC207E1_zps
So I removed the bulbs, drilled the centers to fit a 5mm LED, and threaded the original bulb hole for an attachment bolt. I had to move the bumper up a hair to clear the wiring, but I am pleased with the results.
93A461FE-F28F-43C0-94E3-7FA7024E3AD7_zps
CDE434CC-6C5F-4949-9031-DDFFAE1BE0F4_zps
1000EB66-DC5A-454F-B0F1-029EE4FDA6EB_zps
8DC8C93D-6DA6-49AF-AA58-1D1E82BFC82E_zps
6B60A34C-87B9-4D37-9D98-ABA8AC697F4F_zps
And with my camera flash
5DA433E7-46DD-4BE2-B32B-27CD85EB64D7_zps
  • 3 months later...
Sorry to bump an older thread - where did you get the GMC grille and tailgate?
Also, what about the original Clod grille - how was the black applied behind the chrome?
CPE sells the grill and tailgate.
http://crawfordperformanceengineering.com/advanced_search_result.php?search_in_description=1&keywords=Gmc&x=0&y=0
For the original grille I used an ultra fine paint marker to color in the portion that is supposed to be black.
  • 4 weeks later...
So maybe I'm at take 3 now...
After the last outing, I cracked both front axle tubes. So I replaced them with alloy pieces. While doing so I decided to lengthen the wheelbase and taking full advantage of the 4 link set up. I changed the axle attachment brackets to accommodate the links. I originally had the upper links mounted a little further back, on posts in order to keep the dampers in a straight position.
Here it is before...
And after...
Looks much better in my opinion, and it should handle better as well.
