I'm looking at getting a high lift. I have had a scania in the past with a futaba t4exa. I was never keen on changing gear with the stick and shift gate.
Does anyone know of a radio that allows gear change by a 3 position switch ?
Richard
I have set up a lever on my Sanwa M12 to use for the shift servo. I set it up to have 3 pre-set positions, one for each gear. The lever has a notch in the center, so its easy to find the 2nd position. 1st and 3rd are just full left or full right. You can get to it with your thumb so its easy to shift while driving. Works great!
I had this for a F350 Highlift though, not a truck.
That looks ideal twinset. Great price too !
Seems like a much better way to change. Always find the stick and shift gate fiddly. Shift gates probably work better if your using the mfu I suppose.
traxxas 3 channel radios are much better the 3rd channel switch is perfectly put by your thumb around the handle ...they made it this way purposely for switching gears in there trucks.
$(KGrHqZ,!n4FIp1ucBrKBSKiHukutg~~60_57.J
Is that a 3 position switch though?
My dx3c can assign 3rd channel as 2 or 3 position to any of the five programmable buttons. They don't have three "stable" positions, they act as up/down switches
