My latest build comes in the form of Tamiya's CR01 Unimog. I've always loved this vehicle and wanted to build a crawler. I know there's many others out there that are better, cheaper, and more capable, but I'm die-hard Tamiya. I'm sure with the right hop-ups, it will be more than enough for what I'll be using it for.
I've been gathering hop-ups from across the globe. Seems like some parts are becoming scarce for the CR01. I still have a handful more to be delivered, and I was becoming impatient. So, I decided to start on the body and wheels.
I chose RC4wd's Mudslingers and 3 piece alloy bead lock wheels.
CDBF75AF-025F-44AE-8F8C-801E2267EB4A_zps
Assembling these wheels is a very time consuming task. I think I've assembled a TT01 in less time :D
8007EA95-11A3-409A-96DD-4B8249FD69F6_zps
09DF9CD0-A320-4F13-AFB3-9425204328E7_zps
E4D93C45-9938-44FA-B53B-0554569163E6_zps
EF5AF0C8-3537-4735-9639-173A4616D8D3_zps
79B76C9A-F122-4D8D-AF39-2FB296DE5789_zps
A view of the Mudslinger's aggressive tread pattern
983A0ABA-78D2-43A2-A801-C8FC7DDC35B0_zps
And on to the body...
Before trimming
97C46DFA-DD07-4DC8-A9FB-F2BC3C10E156_zps
Trimmed...a keen eye can see what I did differently
CC863889-6D32-481F-B355-0E10C0972643_zps
When I make an interior for it, I will be using these seats
3F160F09-4C6B-4E6D-A0B0-BBBCC73E2307_zps
Masking
A9E33061-A2E3-4E9B-AF5A-5E3F1BE9F3E6_zps
Black applied
2180C498-6660-4900-960A-15F974BA3AB5_zps
Gun metal paint, by popular demand :)
ECF5A9B7-EE30-4DBE-A8D7-B1D32EA43D79_zps
99A7F822-B6EB-4E1C-A4E7-8520CC64203B_zps
Decals and trim pieces applied
8610AD6F-7E01-4303-B9B9-9CC219EAC205_zps
These are the seats I will be using. They're actually cell phone holders that clip onto your car's heating/air con vents
7FD0287F-A143-4740-8E3D-9362638A85CD_zps
Grinding the rear portions is necessary because of the humps for the clipping attachments
662F2C56-F579-47B3-98CF-421E8B377C7C_zps
A little bit of styrene trimmed to fit the seat backs
501C7380-10D3-4D04-88CA-3F8C171447D2_zps
Here's the original wheel/tire that I will be using as a spare tire
FF64C2C4-DB30-401D-B96E-08221BBAD004_zps
And the hop-up bead lock ring
A2A15CF7-0811-4868-BA81-0240226B139C_zps
B71B7D03-2C12-4F81-99E1-B24D1BF60849_zps
Spare tire mount from RC4wd
82495FE9-181E-4A67-86BC-6D84AB129C99_zps
So, by now I guess you've figured out what a did differently to the body...I cut out the bed and made a drop bed out of styrene
A76EBC4B-F56F-4ADC-8393-273D429885F9_zps
Not mounted yet, just mocking up
8942E36E-4866-40D7-ADBC-BF2B67B98AA4_zps
1482F668-81FE-4017-88EE-409FA8B04BB5_zps
Subaru Brat style :D
DA255045-6A1C-4A4F-A4BC-62FEFA408D4D_zps
I added a second sheet of styrene for added strength and rigidity to support the weight of whatever ends up in the bed (also to hide the glue marks)
7B79630D-FD30-4979-891B-E24CD536E567_zps
And painting the bed
3C9D32F7-3B07-48D6-BFC2-B7866A641394_zps
F6135BBB-914E-4D50-B74B-2A0CC32B3FA4_zps
That's it for now..hoping the remainder of my parts arrive this week so I can get cracking on the chassis.
Thanks for viewing!
Love it so far. Were it me, I'd get a matching spare.
Thanks Emory! If they weren't so expensive I would! Maybe down the road, but as of now, my pockets are empty :(
Like it. Which sets of seats you will be using for the interior?
You must be happy you have an electric screw driver.
You are going to be drained, if you go bonkers with hop ups and add on detailings.
Thanks Tamiya 1/10...I'll be using the ones in the pictures. I had them in the bed just for a silly laugh.
I believe I have nearly every Tamiya hop-up for it. I wanted some from 3racing or GPM for the suspension, but most are discontinued. Integy has all the parts, but I never hear anything good about Integy. So I may leave the suspension alone except for the Tamiya barrel springs and Tamiya dampers.
Look at Junfac for hop up parts. I used them for some of my up grades. But I got rid of the cantilevers and made my own shock mounts. Good luck these are fun trucks.
The last couple of days I've been working on the Unimog's interior. I again chose the Axial wraith kit, this time in clear. A lot of trimming was necessary to make it fit, and I had to trim and flip the dashboard so that it would sit correctly. Also being clear, I had free range of color for it. I'm still waiting on the seat belts and may possibly throw in some scale accessories in before I finally mount it to the body.
The kit as I received it
E0F7C473-D6B5-4BB9-9E47-A7A96049EB1B_zps
After trimming
59588B45-4CAD-4987-95D5-3E3BE756EA3C_zps
Decided to go with a two tone interior
B18299B3-BCC0-4ED9-B53B-992AB1D0F230_zps
Keeping with the theme, I went with gun metal/black
8560506A-0B3C-4C8E-BF57-B02CCF05C825_zps
Luke Skywalker will be driving this one
341D8C50-5628-4678-8264-8998F0DCC915_zps
9683F848-AD0E-470D-803D-300908CA6D5B_zps
I had some gauge cluster decals that I used to fill the interior, I didn't want to use Axial's decals again this time. I also painted the gear levers, steering wheel, and steering column
92C83B9B-6294-49A9-951F-210CF9C0F714_zps
Ok, so I waited until I completed the build to update this thread. My Unimog is all together and I took it for a spin around my basement. I'm really looking forward to getting it outside to see what it can do. This being my first crawler, I am very excited.
Without further adieu, here are my build pics...
Many hop ups going into this build, some not pictured..I couldn't wait any longer, I started before they all arrived
45AC8D38-BDCC-497F-8A25-BB04CF8BECB2_zps
1FF7EE2E-BA08-40EA-8398-FF7B7D5C5557_zps
High luster frame rails vs. original frame rails
155FE34E-3F7B-49AC-888C-165D1F60A726_zps
Parts laid out
BF5FFA10-5302-4D7D-BEC9-0A0887B1F72F_zps
Starting on the suspension/cantilever system
962FB48B-66F5-4124-9068-690A44FB19CD_zps
5F8F86F4-36F0-4E48-BC66-5BD3B8AB0DD6_zps
Ready to install the side frame
E4B7636A-8F26-4E2F-BD8E-CE1F0291BDC2_zps
C54CFAE8-EC19-4519-A9B1-D311199709B4_zps
Carbon mechanism deck
04F1FF51-DA7D-40DA-8ECC-DD874DC57EF5_zps
4062678B-D24C-4AE9-8E81-16A7C54BC219_zps
Frame and deck fitted together
99A32AFF-32BC-4065-A8CC-0F68B2E197F8_zps
Axles and differentials
C9B8605F-1C64-44A5-9BA6-5618B4156909_zps
For the rear axle, I chose to go with the locked differential, the front is open-but packed with a lot of grease
Comparing the hop up hardened shafts vs. original
0258CEC5-B855-4428-BAB4-C848B675FECA_zps
0FDCB7EF-F5C4-406C-A90B-150E64C6CD05_zps
Front differential packed
5847F2A1-9D54-4A19-98AC-9D6B210E8846_zps
Open vs. locked
D8300E27-E092-4266-A08F-C37EEFF58905_zps
BF4D1E36-B981-4685-9518-46FF18C351D9_zps
8FC1C0CC-AA23-4BCC-9B42-5892E56B6D90_zps
Moving on to the axle and suspension mounts
54F29E6B-3FED-47C1-902B-90B34594F920_zps
B0881D18-6453-4001-ACBA-B07F6FC0D5B5_zps
87EA40C7-D981-46D3-B8B5-2F16037F8200_zps
Going with 4 wheel steering-hop up servo beds, Kimbrough servo savers, and Savox water proof high torque servos
13881FD5-DA25-4A21-9EFA-E023C58DF621_zps
B5C20611-13C7-4AE7-BC8B-1F511DF5624A_zps
Hop up servo bed, servo mount, and turn buckle tie rods
83E252BD-C882-4ED2-AEEA-0ABD5F8F431E_zps
Servos mounted to axles
42BE17FB-0416-43B1-9862-0B564E96B3E5_zps
6AB7094C-27F2-48B3-B602-333DECDFCD97_zps
C065C9F4-89C7-4822-A900-DB03E0F0FB98_zps
Next up, the hop up dampers
101197BA-4C57-4159-8DD0-3B357A3E4A98_zps
DF9942EB-05BD-48B1-9284-EAE667687989_zps
3C29500B-6569-484E-AD01-6520AD80276A_zps
Front and rear bent lower arms
257C4794-58EA-4B5D-8AB3-CD4547123A6B_zps
536FC5CB-B274-4D6A-A936-7051B4421864_zps
50E07CE4-6B56-4CE8-855D-F76AD1D6A061_zps
1D7BDE80-E3BD-4BE9-8D88-20C6216F77D6_zps
Shocks and arms
8150097E-3A56-4AF4-9AA7-778B0A30561B_zps
Upper links
0CC4F4AB-064B-4FF3-8B44-E88EEA1D5270_zps
Fitted to axles
97FE7D72-AC23-4D64-A69D-21C9326D1927_zps
Mounting to chassis
8B763179-50F8-4F23-A7CF-4A53B60308B2_zps
6D328361-CA20-45BC-A6B0-A3866B278FDA_zps
Springs installed (at this time the barrel springs hadn't arrived)
BB5C678C-FBD8-4A3D-A837-C5722BAB8BC5_zps
Dampers and cantilever turnbuckles fitted
641E5D70-D1FE-4934-98FB-F62149C45CB2_zps
Hop up front and rear hardened propeller shafts
8CA1A7AB-676C-43FC-B4EA-C839973FA390_zps
2BC02454-D576-461C-83F0-B3E95ED81D4D_zps
Assembling the gear box
ADAFF995-4F3E-4BBB-9B81-3AAE447B8164_zps
F0DBBAF0-F9C0-4E5F-898F-FCD1E8FD5C81_zps
8B099676-33BD-4D61-9178-6124176E2622_zps
39885220-7879-4617-B53B-CFC9904E9755_zps
Motor installation
4F7D6F6C-FA1A-47A1-A97C-433FD3E2636B_zps
Hop up heat sink/motor plate
BBBA0765-2C30-44B4-B6CE-A5FB552613EC_zps
Motor together with transmission
391BAA08-B2BA-41A9-9053-11308811AA8A_zps
And with prop shafts
AD8B267E-2FEB-4835-B580-7B7F3F9EAA58_zps
Hop up skid plate
BF3124FA-54C2-4B03-A2A7-BAFD68CE345F_zps
Original vs. hop up
66F36E6D-FA7D-4BBD-BCA7-8A060BCE70C6_zps
Skid plate attached to gear box
68A47C16-792D-41C9-909D-560062A79B5C_zps
Fitted to chassis
D0F43940-5A8A-41DC-9001-3323E60F31C6_zps
3Racing alloy cross member
6013C81F-3E00-4849-B57F-9DF622152844_zps
BFEF5563-DFC5-4172-B0DD-72B81790BEA0_zps
Front bumper fitted
79A40A03-7F1E-45E4-8627-D977F523DD16_zps
I went with the TBLE-02 esc and a TLU-01 basic lighting kit
22D92DE0-834C-4984-A6B6-6907687D757D_zps
Fitting the battery (Venom 2s Lipo) and electronics
4000C9EC-9C44-4FC5-B323-3D8AD706B7D3_zps
The radio I am using is from RC4wd, and is designed for crawlers. The 3rd channel can be used to alter steering operation.
52CED87E-CFAF-4AF2-B1B1-6C0D27761A1F_zps
Hop up battery holder
A71AE231-8F6E-4FBA-9D95-2209DF8DFD38_zps
With the Castle Creations 20A BEC for those power hungry Savox servos
6FDCBDFD-FAD4-424E-A391-9BE36701E02B_zps
Mounting the spare tire carrier
E6834573-DCE2-46D1-9C0E-BB225CFAAEE5_zps
13C9DA47-41D1-43D8-98E0-921AC11786F7_zps
A85CB0DF-CCA8-48CB-AF61-732FE7393126_zps
Some scale fuel tanks
AB4AC582-C2E1-40B2-9AD7-C812398852EE_zps
Sanded down
63F55FB4-E86A-4F7D-AEFE-AC5485743C3E_zps
And painted yellow for diesel fuel
056B6D99-C355-4391-B394-9446F2F3AAFC_zps
Testing the lights
5D635351-45B6-4933-845B-2328A03952A3_zps
901F8072-D611-4E39-952B-E2DD66617168_zps
At this point in the build, I had been waiting for about a month on the hardened wheel axles and barrel springs. I wanted to get the wheels on so I could set the body, so I went ahead and installed the original axles.
Some more hop ups
2598DE7F-75E8-4B32-9616-3316E3702888_zps
E7CE27D7-4F65-412F-9D7D-5760513755AA_zps
And all fitted
A3B4F630-817F-4605-8C30-07365BCD538C_zps
Wheels mounted, as well as the magnetic body mounts
3E3F9F88-0A08-4BF1-ADE9-A52F00C14192_zps
Fitting the body
729A02E0-425D-4D57-BBDB-18F85D670664_zps
Some flexing ;D
8E585578-ABD4-4A99-961B-D39A403352C1_zps
D803E624-8E52-476A-AED6-BC4CDE00F3B6_zps
18AEBA8D-CE50-4C3E-ADB3-69FCC052E928_zps
B5875CC5-9C72-4C15-A447-474EF9903F41_zps
F7A8C72D-E73D-43F7-A5FE-4C759F655A40_zps
A5D097FB-F4E6-45AA-ABE1-11B5EC36DCCC_zps
4F741301-9444-410B-B8EC-1E2C6C232D68_zps
And just so luck would have it, after installing the wheels and axles, the remaining parts showed up the next day (all but 1 part)
A3F5DBC4-760E-42D7-A366-FFB7CA660B0E_zps
F287FE03-948C-4408-99EE-54E71F70C8F6_zps
Hardened vs. original
68EB838E-7BA9-42ED-B86B-DC08127DE7FB_zps
Original spring
29EAEFBB-C7C2-41FD-8DB7-8ABED8D68BE7_zps
Barrel spring
5AD2EEC6-26B1-46C5-85E4-BC0270BCEC87_zps
Thought I'd share the recent progress.
I thought the bed was looking a little dull, so I decided to add plastic strips to it, like the original had before I cut it out.
Before:
Positioning the strips:
F0BC9CE6-50E2-4F71-8B2D-2C71407EBD54_zps
Painted and secured with double sided tape:
C1EDDF54-25EA-4F70-889F-480DAAFC915B_zps
I also added a few scale accessories.
A high lift jack:
A3B6493C-B56F-4AF5-9976-FA6C1CF49043_zps
A pair of tow shackles:
EF3833E9-55F9-4AC1-9B15-9E2BEB9F18D7_zps
Shovel, axe, and pick:
22B64BB5-6016-4901-A59C-3F849EBB20BA_zps
An engine oil cooler:
A79304C9-54ED-472E-9BA7-8F9EE84CE345_zps
A pair of exhaust pipes:
59ED0BF2-4527-43C2-837C-7F7B34156103_zps
And a tool box:
D701772B-08B9-4E5A-95BE-BAA19090A5E0_zps
And with the spare tire back on:
C5FF9739-D43F-412C-8600-F842E46759CA_zps
Very impressive build Sir . Great choice of hop ups and scale items too . When will we see it getting down and dirty ?
