Hi guys,
I own a Core Code Tx http://www.racing-cars.com/pp/Manufacturer/Core_RC/CR151.html which has a cradle for 8xAA batteries. But I'm sick and tired of the fickle nature of NiMHs and would like to try a LiPo or LiFe in my transmitter. A couple have caught my eye, but I'm not sure if they're wholly compatible.
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=31945
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=46771
If anyone can help, it'd be much appreciated. Does anyone have any experience using the Core Code handset with LiPo batteries? Do you have any pointers for use - do's/don'ts, charging, compatibility, etc...
Many thanks for any suggestions
Tony
I run mine on Duracell rechargeable batteries, lasts a long time and they charge reasonably swiftly too.
My transmitter looks like it would need modification to run a lipo battery. Even then, I would be worried because on several occasions I have forgotten to switch it off which eventually kills the batteries.
Thanks for the tip. I'm pretty good at turning off the transmitter - a tough lesson learned from my one run a day days. I do have some LSD batteries, which I've yet to use, but I find that NiMHs go a bit funny after while, with the odd battery refusing to charge. I dare say that they've been over charged or over discharged.
The safety protected pack is one that I've also looked at and it actually seems a bit smaller than the two I've highlighted. It seems like a good buy, but I'll research a bit further.
Thanks.
I use Sanyo Eneloop in my tx and have been astonished with how long they last between charges, even with weeks between use I find they last months at a time!
Another happy Eneloop user here, too. They last so much better than regular NiMH batteries, and they never failed me - unlike cheaper equivalents (Eneready batteries from Reichelt Elektronik) which died within one year.
Thanks.
Like I say, I have some LSD batteries by Turnigy. I suppose I should try them before anything else. Hopefully better than what I'm using now.
